tmic vac line
Front, Top, Air, Water.
208ss
tmic vac line
Post by 208ss » Tue Sep 26, 2017 10:38 pm
So how do you guys route your vac lines with a TMIC. I have a 91 ss that did not come with a TMIC and the person i bought the car from installed one and some of the vac hoses are not routed right. Some are kinked. Other note the car has a wrx 2.0 block with 22t heads. So the vac port up front is not there.
The TMIC is off a 06 wrx I think.
1991 subaru legacy sport sedan
Re: tmic vac line
Post by Legacy777 » Fri Nov 03, 2017 5:43 pm
Are you referring to the crankcase vent lines?
If so, most people figure out whatever way they can route them. However, it's important to keep the modified routing functioning the same as the stock setup.
1997 Impreza OBS
Re: tmic vac line
Post by cj91legss » Sat Nov 04, 2017 12:09 pm
Just out of curiosity, do you have a pic of the car?
There's a vacuum reference diagram on the bottom of the hood. If you follow that and make sure everything is hooked up accordingly, you'll have better peace of mind.
208ss
Re: tmic vac line
Post by 208ss » Wed Nov 08, 2017 5:43 pm
i will get photos tonight
208ss
Re: tmic vac line
Post by 208ss » Thu Nov 09, 2017 4:56 am
208ss
Re: tmic vac line
Post by 208ss » Thu Nov 09, 2017 4:58 am
This mess. Kinked hoses... missing parts?
Re: tmic vac line
Post by mike-tracy » Thu Nov 09, 2017 5:23 am
The long out of production factory hoses had nice molded bends in em. I've used those plastic 90* elbows and a T in the appropriate sizes, from autozone.
Josh Colombo wrote:
Mon Jan 14, 2002 10:23 am
Wait....I'm confused now.
Re: tmic vac line
Post by cj91legss » Thu Nov 09, 2017 1:47 pm
You'll have to use a different photo sharing site. We cant see anything from photobucket.
