Hey guys. Looking for some stock injectors for my 2.2T. If you could at least do a resistance check on them so we know they are good would be great. That is how I found one of mine is no good.
3 had the same resistance and one had nothing.
Thanks guys.
WTB 2.2T Stock Injectors
86 Brat, 2.2T, AWD, TD04, Intercooled,
88 Rx, Future EJ upgrade soon
Re: WTB 2.2T Stock Injectors
I got a bunch. What resistance range are they supposed to be? I would have them cleaned before you use them, since they've been sitting for a couple years.
My tested at 11.4 ohms but I think if they are close to the same you should be good. Mine all tested the same but the dead one. Another friend's tested at 12 something.
But yeah let me know. I appreciate it. Thx
According to my friend Josh, manual states 11 to 12 ohm range is within spec.
Ok, I'll check mine and get back to you. How many were you needing?
I need one more where I have a complete set, but was thinking maybe 4 good ones that way in case I need to change out I could. How many do you have???
I have probably 2 full sets left
How much you want for a full set?
Id like $60 shipped for the set. I'll check them Tonite.
