Pics can be found here and here
I've got a whole bunch of stuff I'd like to sell off.
$200 I have a set of bare wrx heads, unknown mileage. Great for a build or just put new oem stuff in. Looks like there's one tiny spark plug crack, it's fine. I've ran worse in my car. 1 cam journal could use a light polish. These came off a car that started to develop oil starvation issues. Solved the problem before catastrophic failure. Come with valve covers and all cam caps. Just need a valve train and cams and good to go.
$100 Wrx cams in great condition, unknown mileage. 02-05
$80 Wrx cams in good condition but I couldn't get the cam bolt out. 02-05
$20 ej20/25 center timing cover. Fits any dual cam ej engine.
$60-ea I've got about 7 or 8 axles. front and rear... Some are wrx some aren't. If it's wrx it's from a wagon.
$60-ea 02-05 wrx valve covers I have 2 pair
$60 ej25 drive by wire intake manifold, no tgvs.
$40 4 AVCS cam seals. 2 OEM 2 felpro.
$40-ea TGV sensors and motors
$20-ea cam and crank sensors
$40 Perrin 5 Speed shift knob.
$60 Impreza coupe/sedan passenger tail light
$800 Single AVCS B25 casting ported/polished/built heads. I'm selling these for a friend. Price is somewhat negotiable. Has bc everything. Put your cams/sensors/valve covers on them. Keep in mind I'm the middle man on these.
Cut eBay y pipe. Its good for 2 couplers and an elbow. 10
91-94 turbo legacy front calipers. Been sitting for years, may need a rebuild. 20
Wrx coolant tank hoses. 10
207 pistons with wrist pins. I dont know what year. 60
2 oem security units. Some wiring. Sirens. 80
Coil packs. 20 each.
More stuff to sell. updated 7-15
Re: More stuff to sell.
up!
up.
Re: More stuff to sell. updated 7-15
up.
carfreak85
What are the coil packs off of and what mileage do they have?
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon & Hardtop
1987 & '87.5 RX coupes
1987 RX Type-RA
2002 WRX sedan
2019 Outback 2.5i Limited
1987 RX Type-RA
2002 WRX sedan
They're from various subarus honestly. it'd be impossible for me to tell you mileage. some may be wrx, some may be sti. If i remember correctly the shorter boot is for wrx.
I have 3 black coil packs left. 1 boot is wrx and 2 boots are longer for avcs style heads.
