Currently have 96 2.2 with poor bottom end and a 01 2.2 with poor heads.
Can I replace my 96 short block with the 01 short block?
Using the 96 heads, intake, exhaust and everything that goes with it.
96 Impreza 2.2 and 01 2.2 mix and match?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
Re: 96 Impreza 2.2 and 01 2.2 mix and match?
The phase 2 short block will physically bolt to the phase 1 heads.
The question is head gaskets. I would personally put phase 1 head gaskets on that combo. But you'll want to ensure they don't block off any cooling ports.
Makes sense about gaskets.
I was concerned about piston and valve clearance.
Wonder if it would be an interference motor or not afterwards?
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
I'm sure it will be interference afterwards.
A friend made that combo and had very light valve to piston impact marks with the thinner phase 2 head gasket. He swapped out to a thicker phase 1 gasket and that engine has been going for years.
Good to known
Thanks!
Thanks!
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
