1990 legacy just bought now it won't go into 2nd...
SuperRallyRoo
Well I was calmly driving back from work (seriously I wasn't flogging it this time!) and I go to shift from first to 2nd at about 2500rpms and it pops out of second I think uhm wtf? Then I hold it there and let off the clutch and it GRINDS!!!!! I'm like CRAP! I just lost 2nd?! Well later on trying to diagnose what the heck is going on I realized that if I shift a little bit slower going into 2nd and pull back really hard it will not grind and will not pop out. What could be the problem? I had adjusted the clutch cable more to my liking but I put it back but still didn't fix the problem. Before this and i have only had the car sense saturday... It would sometimes make a TING** sound when shifting into 2nd. Other gears are fine, and they shift smooth I can shift from 1-3rd but thats not going to help me much when I plan to rally cross it in the very near future. Anyway I am hoping maybe my shifter linkage needs to be replaced (or adjusted) and not the tranny synchros. Maybe a tranny mount? Or something? Please help!!!
I love this car and I like 2nd gear... And I talked to Jamie- subiegal about it and she said DON"T force it into gear but I think she might have meant if its grinding.
Legacyless
98 Jetta TDI
98 Jetta TDI
Is it hard to engage 2nd on downshifts too, going 3rd->2nd say?
If it is not hard to shift this way then it does look like the 1->2 synchro. If its stlill hard to shift from 3->2 then linkage looks more likely, unless you are really unlucky and have 2 bad synchros on 2nd gear...
Diclaimer: Just trying to use logic to helpp you debug, not an expert on gearbox internals.
94L Wagon (AWD) - bone stock, 136k miles at July 08. Manual (sold - along with my soul to BMW).
SuperRallyRoo
If it were my car I would be swapping out the tranny oil ASAP and inspecting for metal bits.
Shortly after I'd be giving the linkage a good going over visually. Sounds like something might be either loose or borderline adjusted in the linkage.
Is the tranny oil at least up to level on the dipstick? Does it look clean?
Sounds like you need an expert rather than me speculating, so I'll stand back
SuperRallyRoo
petridish38
Just to clarify... The dipstick on my 90 LS isnt yellow.... its not even labeled..... but it is on the passenger side and goes straight into the tranny. I would check that first.... then I would change it.
Andrew
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
yeah they changed it sometime in the first gen. Apparently the old style (which I used to have and andrew has aswell) didn't vent well enough, and the new style does.
Speaking of which, Andrew, are you sure your dip stick doesn't have "DIFF" printed on the plastic?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
SuperRallyRoo
I noticed something today!!! I can romp on it all day long like normal, but when I go to my special "rally" spots and do some drifts and quick take offs is when the tranny starts to stick when I get back on pavement. It seems to be getting better though, maybe the tranny just needs to be broken into that sort of thing?
It didn't give me any trouble all day today untill I rallyed. Also It looks like im leaking some oil. Sometimes I smell burning oil and today I was test fitting some rims and noticed on the jack when we pulled it out it had 4 drops of motor oil on it.
Could this be a rear main seal? I think the front one leaks too. I would have to pull the engine or tranny to replace the rear main seal correct:?: Thanks!
Legacyless
98 Jetta TDI
98 Jetta TDI
petridish38
My dipstick is all metal and doesn't have anything printed on it.THAWA wrote:Andrew, are you sure your dip stick doesn't have "DIFF" printed on the plastic?
Andrew
209,000 miles!
209,000 miles!
