Starting stats were:
.5 degrees negative camber in the rear
0 toe in the rear
0 degrees negative camber in the front
0 toe in the front
Ending stats:
0 toe in the rear
.5 degrees negative camber up front
Just over 1/8" toe-in up front
Do I notice a difference? Yes.
The car feels GREAT in the turns. Turn in is MUCH sharper with the extra bit of camber, and the extra toe helps straight line stability and increases turn-in crispness.
The car understeers less and just feels BETTER all around. It should have been like this from the beginning. I think I might want to go with a slightly more aggressive camber setup in the front, but I'll see how this setup acts at the limits.
Pics:
