GDB struts in a BC/BF
MY92
Post by MY92 »
Does anyone know if they will fit?
I've "heard" the fronts will fit, but for the rears you have to use BC/BF top hats.
John
http://www.cardomain.com/ride/560635
QuickDrive
Lurker-King
Post by QuickDrive »
I think they fit if you use the GDB struttops too.
R I P-------- 91 Turbo 4EAT --------R I P
MY92
Post by MY92 »
For the rear as well?
John
THAWA
Post by THAWA »
arent the topmounts different? Meaning only our strut tops will wrk?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
MY92
Post by MY92 »
The fronts are apparently ok.
John
Brat4by4
Stratified
Post by Brat4by4 »
Only struts? Then the rears will work.
The front uses a different spring diameter, therefore you need different springs and upper spring perch.
The strut top mounts are all the same on the front. The rear strut top mount out of a GD will not fit our chassis.
MY92
Post by MY92 »
Ok to clairfy.
If I use a complete strut/spring out of a GD it will fit up front.
On the rear however I will need to change the top mount.
John
