Cheap FCD
The $4 Fuel Cut Defender Check valve of magic looks like this:
no part number as i am tired but just imagine looking for this, they have it at napa and its cheap and works.
What vehicle is it intended for, and what function does it serve on that vehicle?SubaruNation wrote:er... define your question for me a lil' better i guess and i can helpbeatersubi wrote:How 'bout an application then?
Vehicle: growler soobbeatersubi wrote:What vehicle is it intended for, and what function does it serve on that vehicle?SubaruNation wrote:er... define your question for me a lil' better i guess and i can helpbeatersubi wrote:How 'bout an application then?
Function: fcd
it's just a check valve
yep supposed to work. you might have to switch it out every so often, i know mine started to die after awhile.
i wouldn't recommend running more than 12 pounds, and make sure you have this and an intercooler.
Good deal!
Thanks Morgie.
							Thanks Morgie.
				jdmellor28
Your car probably hits fuel cut by the time you hit 15 PSI. The car 'initiates' its fuel cut countdown at 13 PSI, and if 13+ PSI is held for more than 3 seconds THEN you experience fuel cut.
So what's probably happening is you start boosting, you hit 13 PSI and the fuel cut countdown begins, three seconds go by and fuel cut occurs right when you see 15 PSI on your boost gauge.
				jdmellor28
				jdmellor28
				turbonator
				jdmellor28
Re:
Auto Zone
Part Number: 47150
													Part Number: 47150
SubaruNation wrote:The $4 Fuel Cut Defender Check valve of magic looks like this:
						Re: Cheap FCD
Sweet. Thanks for looking that up. Could you report back and confirm weather or not your gas milage changes?
							1990 NA 2.2 Open Light rally car
						Re: Cheap FCD
Hey turn was that your SS on craigslist? So far I had I on for about 5 miles boosting 16psi without any fuel cut. Mpg I have no idea yet? I'm thinking no beause I'm boostimg so muh now
Re: Cheap FCD
Omg from the dead!
Your adding pressure, and presumably more fuel in your motor when taking this route so it really depends on how you drive.
Re: Cheap FCD
isn't it letting meter'd air out tho? which would mix up afrs.
