Page 5 of 7
Posted: Mon Apr 06, 2009 5:23 pm
by SubaruNation
yeah i gotta organize myself i will get one up later w/ teh part number
Posted: Mon Apr 06, 2009 11:17 pm
by Grayguy
^ thank you VERY much. greatly appreciated
Posted: Thu Apr 09, 2009 6:35 am
by SubaruNation
The $4 Fuel Cut Defender Check valve of magic looks like this:
no part number as i am tired but just imagine looking for this, they have it at napa and its cheap and works.
Posted: Thu Apr 09, 2009 6:37 am
by beatersubi
How 'bout an application then?
Posted: Thu Apr 09, 2009 6:46 am
by SubaruNation
beatersubi wrote:How 'bout an application then?
er... define your question for me a lil' better i guess and i can help
Posted: Fri Apr 10, 2009 12:45 am
by Grayguy
awesome! I'll see what I can find tomorrow at Napa. If I find a part # I'll post it up here
Posted: Fri Apr 10, 2009 6:31 am
by beatersubi
SubaruNation wrote:beatersubi wrote:How 'bout an application then?
What vehicle is it intended for, and what function does it serve on that vehicle?
Posted: Fri Apr 10, 2009 6:48 pm
by SubaruNation
beatersubi wrote:SubaruNation wrote:beatersubi wrote:How 'bout an application then?
Vehicle: growler soob
Function: fcd
it's just a check valve
Posted: Wed May 06, 2009 9:31 pm
by A1Fiddler
Posted: Wed Jun 10, 2009 1:33 am
by SubaruNation
yep supposed to work. you might have to switch it out every so often, i know mine started to die after awhile.
i wouldn't recommend running more than 12 pounds, and make sure you have this and an intercooler.
Posted: Fri Jul 24, 2009 1:06 pm
by morgie
Hi guys, been a while !
I've restored the links in the first post to the gallery, that way it should be good forever
Posted: Fri Jul 24, 2009 6:35 pm
Good deal!
Thanks Morgie.
Posted: Sat Aug 29, 2009 6:43 pm
by cj91legss
hmm, well i guess this would explain why my legacy dies every so often now...
Posted: Sat Nov 14, 2009 6:45 pm
by jdmellor28
hummm , if you would not want to run more than 12 psi why do you need this ? my car hits fuel cut at 15psi ...
Posted: Sat Nov 14, 2009 8:28 pm
by asc_up
Your car probably hits fuel cut by the time you hit 15 PSI. The car 'initiates' its fuel cut countdown at 13 PSI, and if 13+ PSI is held for more than 3 seconds THEN you experience fuel cut.
So what's probably happening is you start boosting, you hit 13 PSI and the fuel cut countdown begins, three seconds go by and fuel cut occurs right when you see 15 PSI on your boost gauge.
Posted: Sun Nov 15, 2009 1:39 am
by jdmellor28
ok good deal , now i need more info on this fcd . and photos so i make sure to plumb it in there right !
Posted: Sun Nov 15, 2009 6:04 am
by jdmellor28
if anyone has photos of this mod with a manual boost controler installed also i would love to see the photos so i can get it right on my car !
Posted: Thu Feb 04, 2010 1:13 am
by turbonator
Pics Please.
Posted: Thu Feb 04, 2010 4:58 pm
by jdmellor28
I have some pics, i did run this for a while, its ok but i think the MPG goes down ...
i took mine out because when i turn my boost up my clutch slips.
but im in class .. i will post some pics later when i get home
Re:
Posted: Thu Jun 30, 2011 8:15 pm
by darkcrave
Auto Zone
Part Number: 47150
SubaruNation wrote:The $4 Fuel Cut Defender Check valve of magic looks like this:
Re: Cheap FCD
Posted: Thu Jun 30, 2011 11:55 pm
by TurnNburn
Sweet. Thanks for looking that up. Could you report back and confirm weather or not your gas milage changes?
Re: Cheap FCD
Posted: Fri Jul 01, 2011 3:12 am
by darkcrave
Hey turn was that your SS on craigslist? So far I had I on for about 5 miles boosting 16psi without any fuel cut. Mpg I have no idea yet? I'm thinking no beause I'm boostimg so muh now
Re: Cheap FCD
Posted: Fri Jul 01, 2011 6:42 am
by SubaruNation
Omg from the dead!
Your adding pressure, and presumably more fuel in your motor when taking this route so it really depends on how you drive.
Re: Cheap FCD
Posted: Fri Jul 01, 2011 6:24 pm
by darkcrave
Lmao who cares its a 4$ fcd that's works 100%
Re: Cheap FCD
Posted: Fri Jul 01, 2011 6:30 pm
by cj91legss
isn't it letting meter'd air out tho? which would mix up afrs.
