you have PMasc_up wrote:12 is the most you can boost at without a fuel cut defender. After that, if you have the exhaust done, intercooler and preferably new Walbro 255 fuel pump you can boost to 14 psi with the stock injectors. No more though, as you'll begin to run lean and create more knock.
WRX IC install - no hammering - stock turbo
				94SS_Canada
Wow Some great info here!
Yap your right i removed my A/C Do to not working and i needed some space to work on my car
Ive Got a sunroof and power everything so i just cruise around town on hot days and get tanned through the sunroof:D
Thanks for the pic, Does That bracket just act as a ground, You didnt have to extend any wires to move it did you? Also ill be using a blitz 50/50
Im not looking For amazing performance But if i did want to go up to 14 psi, is a fuel pump install difficult?
And when you say create more knock, am i creating more knock by simply slamming a TD04 in there witth an IC?
FastRust
uh aaron knows about knock,, i have no idea.94SS_Canada wrote:Wow Some great info here!
with the backet, yes it does act as a ground so you do need it attached together.
and you dont need to add any more wires to the ignition to extend it, that would blow.
the most you will have to do is un-ravel the wires from their tangle nest in your engine bay
				94SS_Canada
				94SS_Canada
				courtjesterclown
				94SS_Canada
A fuel pump install is easy. Some people said that their lines broke/cracked. Mine didn't so I guess that probably helped.
The TD04 really isn't much bigger than the VF11, though it'll hold more boost to redline. You shouldn't be creating a whole lot of knock if you turn up the boost with an intercooler. You're going to hit fuel cut at 12psi if you don't install a fuel cut defender though.
				94SS_Canada
				94SS_Canada
