Haltech, LinkPlus, or Autronic for stand alone EM
Thanks for the comments Dan.
There's not enough room in that area where the airbag computer goes.
I don't like it, but I'm probably going to have to look at the front passenger foot well.
This is beginning to annoy me.....
It's going to have to go in the front passenger foot well.
http://main.experiencetherave.com/subar ... install/04
I will have to custom make a bracket to support the ECU and fab up a plate to cover it. I've got a buddy with some metal working tools at his house, so I may just go ahead and finish the wiring, get the car running and have to take it up to his house to make the bracket and kick plate.
You could put it in the stock location, but it is a serious pain and since you most likely have the 2m loom, why not put it in the footwell.
I'm half tempted to order a new harness, but I don't know if I want to spend the coin. I have plenty of other crap to buy still, including a lot of paint...
Yeah I have the longer harness. I'm just going to stick it in the footwell. It's just not worth messing with the stock location.
I'm actually going to order another harness for future use or resale, since it's unknown how long Link will be making/supporting the G3 platform.
I've finished the harness and adapter wiring. Finished things up yesterday. I've still got a weekend or two to put everything in the car, wire up the few sensors and put the intake manifold back on, but that shouldn't be too big a deal.
Soldering on the adapter went pretty well. Miles with Fine Line Imports gets a gold star for this project on recommending installing the adapter in the stock ECU case. It worked beautifully!! I hot glued the adapter to the case, cut out openings on the back of the case, and put some tubing around the edges. Hot glue is also what I encased the wires in.
Here's some pictures.
http://main.experiencetherave.com/subar ... install/05
One thing I forgot to mention is that I found out my Zeitronix is the older version which does not have a linear WB output. So I'm going to either need to upgrade or see if I can exchange it.....we'll see.
Plus I'm not sure if the Link even uses WB input to control anything, or if it's just more of an information piece.
asc_up
Post by asc_up »
Legacy777 wrote: Miles with Fine Line Imports gets a gold star for this project on recommending installing the adapter in the stock ECU case. It worked beautifully!! I hot glued the adapter to the case, cut out openings on the back of the case, and put some tubing around the edges. Hot glue is also what I encased the wires in.
Wow what a genius idea! That looks good and should hold up well. I like.
Got most of the wiring done yesterday. ECU adapter is installed, and Link loose fitted/installed in the passenger footwell. I also ran the wires for the IAT sensor and new knock sensor.
I've got to put the intake manifold back on, and do some miscellaneous work, but the main work is over.
http://main.experiencetherave.com/subar ... install/06
Hmmmmm. You're giving me ideas. What kind, I don't know yet, but new ones nonetheless. I just need to see how much harness I do indeed have left.
I ended up cutting about 1.5 - 2 ft of the stock harness off.
I did end up getting a new harness for future use. I did this due to the uncertainty of availability in the future.
I really hate my car at times!!!
I spent most of the day yesteray swearing and yelling trying to get the damn intake manifold back in. The wiring loom under the manifold was hitting the coolant crossover, but I figured that out.....then got everything together and realized I ran the one wiring loom incorrectly and had to remove the manifold. It just was a real pain in the ass!!!!
I've got everything so shoehorned in there that it has to be taken apart and put back together in a certain way. I did it backwards and it just sucks!!!
Anyway....here's some pictures
http://main.experiencetherave.com/subar ... nstall/07/
Continued working on things today. Got the driver's side of the engine bay put back together, and all the extra grounds/power wiring fed into the battery/wire connectors. It looks pretty good, and definitely cleans things up compared to how I used to have it.
I redid the previous ground/power leads I had with 4-gauge wire that is MUCH more flexible. I added extra grounds to the starter, chassis, and a new one to the ground on the intake manifold to tie everything together. I also ran an extra lead to the alternator.
I still need to work on putting the new MAP sensor & boost solenoid in, and need to rework the catch can with some "emissions/oil" resistant 1/2" hose. The heater hose has gotten soft and slimey.
I did however find out something interesting. The catch can was working, even without baffles. How do I know, I spilled oil on the garage floor. I'm probably going to try and add a baffle of some sorts, but it's nice to know it's working to some extent. There's still oil in the intake of the turbo, but I guess it could have been a lot worse.
I'm also going to need to drain the fuel out of the tank. It's been sitting there since October 31st of last year. It may still be ok, but I don't want to be running marginal gas while the car is tuned. I'll throw it in the Impreza, haha :lol:
Here's pictures
http://main.experiencetherave.com/subar ... install/08
Did you get any oil rated hose yet? I previously used Weatherhead for my oil drain. The stuff is a bit stiff to work with though.
I usually go to diesel truck shops for hose like that.
No, not yet. I found some PCV emissions hose on JCWhitney. It however is slightly larger then 1/2". It's 19/32, which would probably work, but I need to double check. I think it was around $13.
Well I'm pretty much done.
I finished up the rest of the items I had to do this weekend. I modified the boost sensor bracket to use the GM parts. I tried making my own bracket out of SS sheet metal. It fits, but looks like ass. I could have finished things off and made the edges look ok, but I still didn't really like how it looks.
I also modified the 45 deg airbox to fit my 'extra' air intake tube. I remounted the catch can, and ended up just using heater hose again. Oh well.
All that is left is to figure out the piping between the airbox and turbo. The 45 deg bend and reducer may not work. things are shifted slightly and may require a complete custom setup. I'm looking for a shop in the Houston area that does custom intake piping.
Lastly, when I went to work on the base map for the Link, I ran across some issues with the new PC Link software. I don't know if the problem is the software (probably is) or if there's something else going on. Dan, I'm probably going to email you about this.
Updated pics are at the bottom of that page.
http://main.experiencetherave.com/subar ... inkinstall
HOPEFULLY I'll have the car running and tuned by the end of May.
PM replied.
Grayguy
Post by Grayguy »
I just pulled the LINK, zeitronix, and TurboXS out of my 98'. It's all going in my 92'. I was just starting to think about trying to make an adapter so I didn't have to cut up my 92's harness, and then I saw yours. Apparently I'm going to need to learn how to solder on a circuit board...
A few questions: For your adapter, did you just cut the front part of circuit board with the connectors off of the rest of it, or did you start all over from scratch?
Also, how hard is it going to be to mount the LINK up near the stock ecu? I only have about 6-8" left on my harness for the LINK and I don't want to/can't afford to buy a new harness right now.
92' SS: SOLD
Max, I think Josh got the last one of their adapter boards.
If you remember, I mounted my ECU in the stock location. I had to make a small bracket for the inboard side of it, but it fit. It is pretty cozy in there btw. I left about two feet on my harness though.
Grayguy
Post by Grayguy »
Damn. The main reason I wanted the adapter was I don't want to cut up my harness, after going though the trouble of having to find a new one after I cut up the one im my 98'.
I was also thinking if I could build the adapter, than my car wouldn't have to be down for more than a weekend to put the link in cause I could do most the wiring stuff before hand...
I'm also trying to decide if I want to do the LINK at the same time as my DOHC's or if I want to do it before hand to get all the kinks worked out, what do you think about that matter dan?
92' SS: SOLD
I may or may not try using a blow torch to desolder an ecu header from one of the few ecu's I have laying around here. After connecting wires to the header pins I would encapsulate the back side in epoxy or hot glue so the thin header pins don't fatigue and break over time.
We'll see if I give it a shot or not. I have a lot to do before I get to that bridge.
As Dan mentioned, I got one of the Link Adaptalink boards. As Dan mentioned, I think a blow torch is probably what you'll need to use to get the pins desoldered from the board.
From there if you get the connector desoldered, you need to probably have a custom PCB printed to solder the Link harness too.
Your other option would be to repin the stock ECU connectors on the chassis side. There would still be some additional tweaking, but I think it's doable.
BTW I figured out my issue with the PCLink software.....I don't think I was all there yesterday.
Good good. Is it going to run tomorrow ? :-D
I don't know about tomorrow. I completely drained the gas tank. So I've got to get some gas in there before I do anything. But my hope is to try starting her up this week.
Grayguy
Post by Grayguy »
What exactly is this? I'm not sure what you mean. I might have to pull the ecu out of my spare t-leg. I've never even looked at one for these cars before.
92' SS: SOLD
The connectors are the same.
Stock ECU
http://main.experiencetherave.com/subar ... P_6544.JPG
Link ECU (yeah I know, not the greatest picture)
http://main.experiencetherave.com/subar ... P_8852.JPG
You take the pins in the stock connectors that plug into the stock ECU, and you move them around. That way, you can just plug the stock ECU connectors directly into the Link ECU.
