Added another to the collection. (updates,SIDESWIPED!)
The wasted spark coil pack 'fires' two plugs are one time. Hence the term 'wasted spark'.
The ignitor is basically just a dumb switch. The ECU turns it on to charge, then turns it off to fire. The reason for that is so the relatively high current used to charge the coils doesn't need to run through the ECU.
Each pair of coils in a coil pack fires two plugs. In laymans terms think of one plug gap as the (+) and the other plug gap as the (-). The coil-on-plug setups use one of the mounting bolts for the (-). Of course that's not exactly what goes on, but should help with the visual.
dropdfocus
Ok, so I was already thinking along the correct lines. Thanks again for the quick info lesson!
It's always great to have knowledable resources on the fourm.
Jason
No actual changs yet, still stock. Not sure it's worth putting in an intercooler knowing that an EJ20G setup is coming soon. It seems that any intercooler is a lot of work, especially if your trying to make it look totally stock to pass a California emissions test.
Some test fitting pictures. No inlet pipe attatched in any of these pics yet.
dropdfocus
Taken out for test fitting. It's still in the factory spot for now.beatersubi wrote:Where's your coolant tank?
I've pretty much decided to stop working on an EJ22T intercooler setup and will just accelerate my EJ20G (EJ22T block, EJ22G?) install instead.
They say it's the small things that matter most, right?
How about a variable intermittent wiper? The fixed intermittent wiper was always a pet-peeve of mine.
Saw these at the local Pick-N-Pull, figured what the hell....
dropdfocus
How freakin' true!!!PhyrraM wrote:They say it's the small things that matter most, right?
What was that snagged from? From the looks of it, a BD or GC series wagon...? I did the same swap in my Focus ZX3 and all you did was swap out the stalk since it controlled the delay from there. Same scenario again?
Jason
It's from a pre-facelift BF wagon. It was a non-turbo, but higher end model (LS?). I've been checking every single BC/BF I come across in the yards. It seems like this 'option' was really rare.
Yes, It plugged right in. Hardest thing is removong that metal anti-theft shield under the column to pull the wires.
With the new steering wheel in, I figured it was finally time to stop stareing at the airbag light. If you recall from page 1, it's been on since I bought the car.
It turns out that the airbag light is not just a simple light.
It's an entire module that plugs into the rest of the cluster.
I generally like to modify as little as possible in case I decide to sell the car later. So I just lifted the wires on the bulb (like a Xmas light) and put it all back together.
I also found the shear bolts that hold the ignition switch to the column completely loose. Of course there is no way to tighten them once the heads are sheared off at the factory. I cut slots with a grinder and tightened them back down with a large screwdriver.
The catch? Well, I made some kind of mistake when re-assembling the cluster. The fuel gauge reads full. All the time. With any amount of gas in the tank. I guess I'll just go by mileage for a few weeks untill I can pull the cluster out again.
I really don't know what went wrong, as it's actually pretty simple to take the cluster apart. I'll be sure to let you all know just how bumb I can be, when I get it working again.
very nice and detailed writeup man keep up the good work.. i guess its very rare people are building these like you are anymore with informative pictures.. i really like your setup...
2005 STi (500WHP with "SlowSTi" as the license plate lol (Weekend Warrior)
1991 Legacy ss JDM EJ20G swap with STi goodies (DD)
Thanks!fatgc8 wrote:very nice and detailed writeup man keep up the good work.. i guess its very rare people are building these like you are anymore with informative pictures.. i really like your setup...
It was always a pet peeve of mine to see others work on thier cars and only show the finished result. Then when you go to do it yourself, you find out some missing detail that derails the whole project. I'm trying to fill in as many gaps as possible.
lmaoooo i feel the same way too dude... we always manage to see a good looking car with all these mods but no writeup on how it was done.. anways good looking ss man now lets see that hybrid ej20g/ej22 build you got going on...
Thanks!
[/quote]
Thanks!
Well, just shy of 259,000 miles I have a water leak somewhere near the waterpump. Can't see if it's one of the hoses, the weep hole, or something else.
Usually it's not a problem. As indicated in my sig, I've got an '02 WRX that was my daily driver up until I got this car to keep the miles off the WRX. Well, the WRX has been neglected for so long the battery was dead. How's that for wanting to drive the O.G.?
Probably won't have time to look at the Legacy until after New Year's. Most likely this coming weekend. Let's hope it's simple, the EJ20G/hybrid isn't ready yet.
I found some time over the holiday weekend (5 days for me
) to check out my newfound water leak. I took apart the whole front of the motor. I didn't actually find anything totally conclusive, but most of the hoses and the pump iteself looked like thay had seen better days. So I replaced them with good used parts I had from donor motors.
Why used parts? I don't expect to go more than another few months before the EJ22G (possible EJ23G or EJ25G) swap.
I DID find something interesting. The front oil seal had been pushed out of it's bore and was rubbing on the back of the crank timing pully.
It was leaking oil, but it wasn't causing the massive lossl that you would have expected. There must have been at least a tiny lip that still remained in the bore. I, personally, haven't seen anthing like that before. And I've seen my share.
My Subaru Tensioner Resetting Device (tm)
Pressure washed it all down and reassembled, sans the timing covers. I want to see it if it starts leaking again. (again, motor is pulled soon)
Filled it up with water and a bottle of Prestone(?) flush and took the kids to go see the snow with my bro, sister, and her husband and kids. Yep, here is SoCal, snow is a novelty to be traveled to -not a chore!
My brother happens to have an '01 2.5RS.
The Forester in the background is a bonus!
Maybe I should have checked for water leaks before leaving?
For the final turbo, I have a 90 degree inlet TD05 from a ~'95 WRX. The smaller turbos were mainly for testing so I wouldn't have to change the tune.BC5RA wrote:Not sure what you're going to do ultimatly, But neither of those turbos will flow 300hp if you had to pick one then pick the TD04 mainly because its newer tech will spool a bit quicker then the VF10.
I do have the intercooler, but have not sourced a pump or heat exchanger yet. The proper JDM parts are hard to come by and it seems the OEM Subaru pump has occasional bearing problems. If I do a water-to-air intercooler I'll most likely follow Josh's lead.BC5RA wrote:Also can you get a hold of a WAIC?
Coming from a RS/RA owner I'll take that as a complement.BC5RA wrote:Nice work
Oh a TD05 will flow plenty, What parts do you require? what sort of gas can you guys get a hold of?
Could you give me a link to Josh's setup?, the pumps do fail but not that often, MRT in Australia used to a larger heat exchanger and highflow pump (the heatexchanger was basically two welded together.
I'm pretty out of touch with the setup of USDM legacys.
I take it you'll collect all these parts and then tune it with aforementioned Power FC.
Let me know I'd be happy to help, we've still got loads of parts over here easy to take for granted.
I always appreciate anybody who learns and works on there own cars, and i like white legacys
The best pump gas here (without spending 3x the price) is 91 octane, close to 95.5 using the more common RON rating used in the rest of the world. I currently only have a black series 2 exchanger and the twin pipes mounted on the intake manifold. Anything mounted on the chassis itself I do not have yet.BC5RA wrote:Oh a TD05 will flow plenty, What parts do you require? what sort of gas can you guys get a hold of?
Here is Josh's latest intercooler thread. http://bbs.legacycentral.org/viewtopic.php?t=35394BC5RA wrote:Could you give me a link to Josh's setup?, the pumps do fail but not that often, MRT in Australia used to a larger heat exchanger and highflow pump (the heatexchanger was basically two welded together.
Basically a closed deck EJ22. Same crank and rods as EJ20G RS/WRX with a cast piston @~8.0:1 compression. Very small turbo, non-intercooled. SOHC heads, most likely very similier to your EJ18 SOHC heads. Wasted spark coilpack instead of your coil-on-plug setup. Built for low end torque that us Americans supposedly love. The good news is that our harness and ECU pinouts are 98% compatable with EJ20Gs. Only a few pins to swap, so the PFC conversion was very easy.BC5RA wrote:I'm pretty out of touch with the setup of USDM legacys.
Yeah, self done road tunes for now. I tend to prefer good condition used parts. These cars ARE 15 years old now, right? As soon as I get my EJ22 hybrid (EJ22 or EJ25 block w/ EJ20G heads) installed I plan to get a proper dyno tune. It's a shame that dyno time is so expensive, I really would have liked to add real numbers at every stage of the build so far.BC5RA wrote: I take it you'll collect all these parts and then tune it with aforementioned Power FC.
I will. Thanks.BC5RA wrote: Let me know I'd be happy to help, we've still got loads of parts over here easy to take for granted.
Ditto.BC5RA wrote:I always appreciate anybody who learns and works on there own cars, and i like white legacys
91. Hell, i run BP ultimate 98 (97.5 octane) though the aformentioned chip is tuned for 95.
A closed deck EJ22 block is every desirable thing over here in NZ and Australia.
99.9% of 1st gen legacy have a closed deck EJ20 block and some early WRX's
For install, setup and tune for a name brand computer (LINK, Autronic, Microtech, HKS etc) would cost about $2500NZ drive in drive out.
To spend a tune on the dyno would be about $500NZ, i'm not really all that impressed with dyno tuning, obviously you get to a point when it is necesary (larger injectors being one) many over here do an exhaust, intake and larger bolt on turbo and then tune, or should you wait? One good friend of mine had done many mods on his legacy and ended up with a slower car until it was on boost (4500rpm) due to it being poorly setup.
It's all about setup in my opinion
And that's miles, bitches!
In other news....
The '06 WRX 17" wheels and crappy chinese tires (don't ask, too embarassing) started to develop a vibration. So I decided to take them off and re-install the '99 RS 5-spokes, as those are the only other wheels I have that will clear the 4-pot/2-pot brakes.
The bastards that installed the tires must have been monkeys with the impact wrench. I now have at least 1 stripped or broken stud on every hub
On the brighter side....
I can start my engine build. I've finally got all the 'hard' parts. According to people I trust, the early EJ251 cranks were machined for both thrust locations. So I picked one up from an '01 2.5RS. My brother wanted the heads, so my net cost for the complete 134K shortblock was $130. We even got a complete '99 2.5RS intake manifold too.
Upon first inspection, it does appear that this crank is machined for both thrust locations. A post in the engine forum will follow.
The parts I have so far:
Numerous EJ22T blocks to choose from.
EJ251 phase 2 52mm journal crankshaft.
CP EJ22T stroker pistons, used but machine shop OKed.
Pauter phase 2 EJ25 rods. Used, but reconditioned.
Stock '93 WRX EJ20G heads.
Stock V2 STI "555" edition
90 degree TD04, 90 degree TD05 and a VF10 to choose from.
And of course, the Power FC is already installed and running to control it all.
Still need all the 'soft' parts. Gaskets, bearings, pumps, etc....
Wish me luck.
It's been a while, but I have a few updates.
My block, crank, rods and pistons have all been sent to the machine shop. I chose Millenieum Motorsports in Temecula, Ca based on numerous recomendations. It turns out that my used CP pistons will not work in even my best EJ22T block. So I had them order new CP pistons, rings and retainers. They are also machining the block for a phase 2 crank. The EJ25 crank and Pauter rods are in perfect condition, so that's good.
I traded a few parts off for a Garmin Nuvi 760 GPS unit. It also does handsfree Bluetooth and plays MP3s off an SD card. I installed a pre-facelift stereo with the input jack to compliment the unit. I also installed an old school Sony CDX-C910 below it. That's the one with the copper plated chassis and the Burr-Brown DACs. It's not hooked up yet, but will be the basis of an 'ol school Sony/Soundstream SQ system. I do plan to stealth and hide the wires as soon as I decide exactly where I'd like the GPS to sit. So far that corner seems unobtrusive.
During a random junkyard sweep I saw these switches. I've never seen them before. I don't know if they are a factory, dealer or aftermarket part. Even though they are labeled as heated seat switches, you can never have enough "factory" style switches.
Also picked up during the same JY trip was this clean post-facelift manual transmission instrument cluster. I need the fuel gauge to replace the one I broke when I disabled my airbag light. The fual and temp gauges are part of the "facia" so I needed one from a 5-speed. I'll post a how-to if there is interest.
Finally, I decided on tires. I was up in the air on alot of descions. 16" or 17"? Street or rallycross? WRX size or Legacy SS size? I decided on a middle ground, mostly because I can't justify the cost of 2 sets of tires.
Yup, I know what your saying......" WTF? Generals?" I said the same thing too. But reality says I don't need a full-on max performance summer tire. And these came well recommended in the rallycross community as a good dual purpose rallycross friendly tire. General tries to sell these as a pure performance summer tire, but reviews actually place it closer to a really good performing all season. I'm OK with that and the tread really does look good for rallycross here in SoCal. We'll see. ~$350 @ TireRack. $404 shipped to my door. I though that was reasonable.
Aren't they purrdy? Hopefully something will get installed this weekend.
With the motor finally in the machine shop, I figured it's about time to get one of these. Harbor Freight has them on sale currently. $150 (+$30 for the balancer).
I bought that same hoist from harbor freight a few months ago. It's great. I didn't get that balancer though. It would be nice.
