Page 5 of 5
Re: Koyo & Mishimoto Radiator Failures!!! (Legacy Turbo Mode
Posted: Tue Dec 23, 2014 10:32 pm
by James614
I say chances are decent they will bring in more. The radiators are the same as the early WRX, so the supply is out there. I remember ordering parts in the past and they were put on special order from Japan.
Posted: Wed Dec 24, 2014 10:45 pm
bmxpunk wrote:Anyone had any experience with a Spectra? Also I have seen conflicting reports that the stock radiator was 2 row while these replacements are 1 row.
I did a little research and the Spectra's 1 row is almost twice as thick on the turbo radiator. I'd still recommend trying to find a stocker, but Spectras would probably work too.
The CU1819 is the turbo model
http://ecat.spectrapremium.com/produits ... ons/CU1819
The CU1183 is the non-turbo model
http://ecat.spectrapremium.com/produits ... ons/CU1183
Posted: Thu Jan 01, 2015 10:29 pm
by bmxpunk
Found a stock radiator and fans at a salvage yard in Colorado that will be here Friday. Looking forward to building a new lower radiator mount and installing it.
Posted: Mon Mar 23, 2015 2:22 pm
by mittens
My wife's 92 radiator just blew and I was quoted about $140 for a replacement from O'Reilly auto parts (former checker, schucks kragen) ; anyone have experience with these replacements or should I just go to the stealership?
Also, has anyone ever considered welding aluminum end tanks to an old stock core? I'm thinking I might try it with hers when I get a chance.
Opinions?
Posted: Mon Mar 23, 2015 3:04 pm
by James614
I can't say if it's as good as OEM, but my cheap Autozone radiator in my Touring Wagon was still in great shape after 6 or so years of hooning and quite a few autocross events. Whether it's worth it I guess would depend on how much the OEM one costs. I wouldn't consider the radiator a critical part to go OEM on like the engine parts or sensors.
Posted: Mon Mar 23, 2015 5:49 pm
I did not have a good experience with autoparts store radiators. It wasn't necessarily with the build it was with the fitment in my Impreza. So if they have the radiator and you can compare the old vs. new to make sure it's exactly the same, then great. I recommend staying with the aluminum radiator with plastic end caps vs. a copper/brass radiator. This recommendation is due to the dissimilar metals and galvanic corrosion.
Here's a quick link from google with more info.
http://www.cgj.com/2013/07/02/aluminum- ... ptibility/
Posted: Thu May 25, 2017 8:23 am
by bmxpunk
Does anyone have any experience with the new Koyo racing radiator for these cars? Part number VH090302. They have a new core design and are only 36mm thick compared to the old units that were 2"+ thick?
Posted: Mon May 29, 2017 10:15 pm
by jamal
I like the newer v-cores. Without better airflow through the front a really thick radiator doesn't benefit a whole lot. Plus clearance is really tight between the fans/hoses/engine on the older cars with a thick core like the koyo R or mishimoto. I recently tried putting a mishimoto in a GC and it basically didn't work with the stock fans. And then like 2 months later I see koyo released a v-core for that car.
Anyone wants to order one let me know, I can offer pretty decent pricing.
Posted: Tue May 30, 2017 12:42 am
by bmxpunk
Sending a pm. Function auto? That's me name over at dirty Impreza I think. That's what we called our first rally team.
Posted: Tue May 30, 2017 1:12 am
by jamal
Ha, funny. I went with that because I run hellafunctional, so, it's like a parts store spinoff, and looking like some shop space soon too.
