Page 5 of 6
				Re: Custom Grille v3.0
				Posted: Fri May 10, 2013 10:39 pm
				by originalcyn
				Thanks for the input everyone. So i guess the question is, while it looks unique, that's not necessarily the same as good. Do you guys like it without the trim at all, or with the trim in front of the mesh, or in the small surround channel? I can't think of another place to put it honestly. it'd be nice to figure out how to get it behind the mesh.
				Posted: Fri May 10, 2013 10:40 pm
				by originalcyn
				Procuring materials:
				Posted: Sat May 11, 2013 2:48 am
				by beatersubi
				I think it wouldn't show up enough to be noticeable behind the mesh. Have you considered any other colors? Like a silver or grey maybe.
				Posted: Sun May 12, 2013 5:00 am
				by originalcyn
				beatersubi wrote:I think it wouldn't show up enough to be noticeable behind the mesh. Have you considered any other colors? Like a silver or grey maybe.
Red is a little ricer i guess. But cause my badge and calipers and sways i kinda want to stick with red.
here's where we're at:
Finished my sanding. looked ok:
Turns out I can't tell what's good and not and also have zero depth perception. When I added a layer of plastidip to look to see how wavy it was, well...it was pretty wavy.
Anyways, the solution might be (besides learning how to actually do this) glazing putty. I picked some up, along with some body filling primer today. I'm always curious what these kinds of projects end up actually costing.
				Posted: Sun May 19, 2013 12:17 am
				by originalcyn
				Primered it the other day. It's hard to tell in the pictures, but it's still kind of wavy. I need some serious practice learning how to sand.
Right now I have some glazing putty to put on, and some more sanding. But this looks like it will be the last bit of body work to the plastic before the final primer and paint. I still need to put the mesh in obviously.
				Posted: Sun May 19, 2013 3:17 pm
				by cj91legss
				Looking good. Where did you get the mesh?
				Posted: Sun May 19, 2013 7:05 pm
				by originalcyn
				Posted: Mon May 20, 2013 8:01 am
				by mike-tracy
				Good one K
				Posted: Mon May 20, 2013 8:57 am
				by originalcyn
				So not intentional. i had to go back and edit the comment so people knew i wasn't making a terrible terrible pun. lol.
				Posted: Mon May 20, 2013 9:14 am
				by kimokalihi
				To get the wavyness out you probably need a sanding block.  If you use something soft like your fingers you're going to sand both the peaks and the valleys and you won't get very far.
				Posted: Mon May 20, 2013 3:01 pm
				by Lego22T
				I've been looking for the good old stand by of aluminum gutter guard but everywhere I look (Lowes, Home Depot, True Value, Ace, etc.) they only sell the nylon crap. Guess I'll be utilizing the garbage can mod as well.
				Posted: Mon May 20, 2013 10:16 pm
				by originalcyn
				Thanks Kimo, I was using those sponge blocks, but they didn't help that much. Maybe i need to buy the real blocks. But it's hard to get those in there with such little space.
Lego22T, Honestly, the gutter mesh is too open (personally). I started with that stuff. The garbage can mesh is way better, finer mesh, feels higher quality too, and shapes better.
				Posted: Sat May 25, 2013 8:20 am
				by originalcyn
				Posted: Sun May 26, 2013 5:28 am
				It's looking good!
				Posted: Sun May 26, 2013 4:22 pm
				by Lego22T
				Scuff the backside with a 40-80 grit sand paper and sandwich the mesh into a layer of Bondo. That is a technique that has been used on aftermarket bumpers for many years. I've done that in the past on several projects with good success.
				Posted: Sun May 26, 2013 6:39 pm
				by originalcyn
				Thanks Josh!
Lego22t, so that's how they do mesh in aftermarket parts? What I'll probably end up doing is spotting it down with 5 minute epoxy and then fiberglassing over the back. I've had bad luck with bondo on previous reiterations of this specific project, so i'm a little reluctant to try again. I'm positive i used it in the wrong application, but fiberglass just seems so much more solid.
				Posted: Sun May 26, 2013 6:44 pm
				by kimokalihi
				Bondo sucks when you use it in ways its not meant to be used and that would be one of those ways.  It'll crack and come off.  Use epoxy instead.  Strong and it'll last forever.
				Posted: Thu May 30, 2013 9:22 pm
				by originalcyn
				Yeah, i've had bad luck with bondo. Epoxy seems to be the way to go, or resin for fiberglass. Either way, I'm starting with epoxy.
Of course the clamps messed up the surface, so i had to glazing putty again. but that's all in the past.
				Posted: Fri May 31, 2013 2:43 am
				by beatersubi
				Welding clamps for bodywork FTW!
				Posted: Sat Jun 01, 2013 7:19 am
				by originalcyn
				haha yeah.
Legacy Central - Make Due With What You've Got.
				Posted: Sat Jun 08, 2013 1:59 am
				by originalcyn
				Posted: Tue Jun 11, 2013 7:38 am
				by originalcyn
				I painted the LS badge before, and it had turned out...alright. Heartened by the experience, and figuring I could do better this time around, I gave it another go.
Only for it to end in utter disaster.
Pushing forward, thinking that plastidip might be the solution, and provide easy clean up for when I screwed up, I arrived at this.
Of course, that didn't work either. Why should it? I was being lazy and didn't want to prep the badge yet again. But ultimately it came down to it anyways. The local hobby store is apparently a nice solution. So the badge is stripped down completely (again). Enamel paint was recommended for durability, and it's what I had used last time anyways, at least for the lettering.
So several layers of black enamel, and 48 hours of drying left me with this.
'course, it looks like garbage again once I start hand brushing in the letters. I will say that the pictures make it look a lot worse. The hand brushing is apparently the option for me that works best though.
				Posted: Thu Jun 13, 2013 2:14 am
				Painting is all about the prep work.  If you don't prep properly, it has a less likely chance of turning out well.
				Posted: Sun Jun 16, 2013 8:50 am
				by originalcyn
				blarg i just have so little patience. haha. the badge is shaping up nicely (5 ft or greater distance) so hopefully i can put it on the new grille soon.
				Posted: Wed Jul 31, 2013 7:42 am
				by originalcyn
				Well, after an extended hiatus, and a long arduous journey of self discovery, I've finally resumed work on grille v3.0.
First step was to pull out my old grille. For as many grille as I have laying around, I have practically no chrome trim pieces. The only intact one was on grille v2.0 (and I even managed to break it a little bit).
Hit it with like 6 coats of plastidip. Plastidip seems to be the only moderately decently solution for the chrome, at least that I've come up with, which i guess isn't saying much.
Finally all back together.
Final paint - layer of plastidip on the mesh. Just a fyi. I painted the mesh on grille v2.0 with a bajillion different things. Almost always ended up chipping out. Save yourself some effort if you're going the mesh route and just plastidip it. Holds up remarkably well to whatever hits it on the road.
I should be able to start adding the final pieces tomorrow! or maybe later...
