Tony's 91 SS 29Dec R.I.P.
Re: Tony's 91 SS
Post by SILINC3R »
Wonder why the MAF harness was designed like this.
All spliced together with new harness
For that factory look
Lots of stuff to still wire up
Re: Tony's 91 SS
SILINC3R wrote:Wonder why the MAF harness was designed like this.
Because it's a shield cable.
Re: Tony's 91 SS
Post by SILINC3R »
Lol, I guess that was a dumb question. I just would thing it would be affected by anything. Is it for heat and noise?
Re: Tony's 91 SS
The shielding is for electro magnetic interference (EMI) also sometimes referred to as EMF. Every electrical wire produces some EMI, but it's primarily caused by non-resistive high tension spark plug wires.
You could probably get away without shielded wire, but the factory overdesigns things, espcially when it comes to sensors that are lower voltage and affect the engine's direct operability. Crank, cam, knock, & MAP sensors also have shielded wires.
Danny-G
Re: Tony's 91 SS
Post by Danny-G »
What are you up to with a height control switch? Are you planning on adding the factory air suspension or something else?
Danny
Re: Tony's 91 SS
Post by SILINC3R »
Josh-Yea I kept it all wired the same so I shouldn't have any problems. Good to know it was overdesigned. If only they could have overdesigned and put a top mount in for us lol.
Danny- No air suspension for this car but if I have an open spot I'll stick it in and wire power to it for the little bulbs.
Re: Tony's 91 SS
Post by SILINC3R »
Got some of the parts in today, can't wait to start putting it all together.
Re: Tony's 91 SS
Nice parts man! I really need a turbo shield or chimney cause I'm heatsoaking like a mug. Also let me know if you have any issues with my parts.
Re: Tony's 91 SS
Post by SILINC3R »
Starting to try and put the engine back together. New gaskets for the DP and UP.
Turbo blanket installed
Ran into a problem. Oil line doesn't fit with TD04 have to run to Subaru and get one ordered.
Re: Tony's 91 SS
Why doesn't the oil line fit? Can't you bend it a little bit to make it fit?
Re: Tony's 91 SS
Post by SILINC3R »
The bend at the bottom point bends in a way that wont allow it to be connected and the last thing I wanted to do was kink it and starve the turbo lol.
Re: Tony's 91 SS
Post by SILINC3R »
Done with most of the wiring for the leveler switch and fog lights.
Harnes for leveler switch
Like it should have come from factory
Fog light power wire
Just mocking things up
Re: Tony's 91 SS
Looks good Tony!
Nice work with the wiring!
Re: Tony's 91 SS
You have a fetish about taking your dash out for any reason, lol. Good work on everything so far.
Re: Tony's 91 SS
Post by SILINC3R »
^ Yes Mike I do lol.
SO haven't done much since the last update, trying to pay off stuff before I go crazy with buying parts. I was hoping to have it rolling around X-Mas but I want the car to be almost done before I drive it again. I'll wait to do the tranny swap but I am going to change the brakes out again to 4/2 pots and put some coilovers on and that should do it for the extra stuff. But when this car is done it will be like factory so no messing around.
livestrong14
Re: Tony's 91 SS
Post by livestrong14 »
Looking good! Nice fender braces!!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
Re: Tony's 91 SS
Post by SILINC3R »
Well finally had some time to work on the car thanks to Ben(legacy4ever) for hooking me up with the connectors I needed so I could make this a factory install of all the lights and what not. Haven't finished everything as I am waiting to buy the correct gauge of wire. I am tired of using wire that is way to think like 14-16 AWG since that is about as small as you can get at home depot and even autozone. I will be buying like 20AWG shortly and hopefully be done with wiring by X-Mas. I did get a chance to do some more on the leveler motor wiring though.
And then I spent about 2 hours taking apart the old VF11 and cleaning it to make a nice paper weight
Re: Tony's 91 SS
Sure is pretty! Too bad it sucks so hard. Err. You know what I mean.
Re: Tony's 91 SS
mike-tracy wrote:Sure is pretty! Too bad it sucks so hard. Err. You know what I mean.
Hahaha
Re: Tony's 91 SS
Post by SILINC3R »
These just came in the mail from NZ, Monsoon Rainguards
these are just test photos
Danny-G
Re: Tony's 91 SS
Post by Danny-G »
Jealous!!!!!!
Danny
Re: Tony's 91 SS
I want some!
Re: Tony's 91 SS
Hey tony, you finally got something that I don't have, but want ;)
Re: Tony's 91 SS
Divulge your source or I'm never helping you work on your car again.
Re: Tony's 91 SS
beatersubi wrote:Divulge your source or I'm never helping you work on your car again.
"Like"
