New wheels & now 100% more gt30 and rotated intake manifold!
bmxkelowna
Re: New wheels & now 100% more gt30 and rotated intake manif
Post by bmxkelowna »
that intake mani is just sitting there for mock up i have a spare one with all the egr stuff cut off and welded shut and also i cut the brake booster vac nipple off welded the hole shut and moved it to the other runner thats now in the back
Awesome.
fasterthanyou
Post by fasterthanyou »
Wont you have to modify your throttle body, or cut a hole in your hood to get it to fit under the hood?
bmxkelowna
kinda like this?
Dominator
Post by Dominator »
That motor looks SICK!!!
bmxkelowna
looks like this right now, should have the heads back saturday and motor build and installed sunday?!
25d heads are getting 20k cams and 257 valve springs
fasterthanyou
uh, ya, kinda like that. haha
you should put a motor build list up
Port and Polish? deshroud valves? injectors? ECU? and are you doing pistons?
and did you custom make the bracket for your alternator?
bmxkelowna wrote:Image
:smt023
More!
bmxkelowna
BUMP
FINALLY got the r200 sorted, 1st event with it the subframe folded since i cut too much and didn't reinforce it enough which then broke an axle. second event the diff wasn't mounted solid enough compared to a 240sx which lead to the nose of the diff moving up and down, breaking the alu diff cover and an other axle
now this is what everything looks like
the front T bar now has solid "bushings" and also bolts to the subframe on the drivers side to the front lateral link bolt
car feels amazing with the gt30, v4 sti cams, the nissan 4.08 final drive and the retune from rob
only issue now is i finally broke the tranny ive been using for 4 years, lost second gear. thats okay, i continued the rest of the day in third only with the extra power haha
bmxkelowna
fasterthanyou
requesting an engine bay shot
haha
great job on the rear diff setup. that looks like some quality workmanship. nice welds and i love the great ideas to make things work
Looks good Logan!
