Page 5 of 7
Re: Direct fit AWIC kits on the way.
Posted: Mon Sep 24, 2012 8:16 am
by Turbo_Carl
kimokalihi wrote:What was the cost of everything? I could look....but it would be nice to just have that info here. I like the video and you should make more of the rest of the install. Did you have to cut anything to mount that heat exhanger in the bumper?
Rest of the video is going to be posted soon. I have to merge some stuff together and edit it. I will explain everything there.
Parts list will be posted along with the vid. Everything together cost me $530 or so. (Military Discount too) Probably would cost everyone else about $550 or so.
ride_child wrote:what if you take out the ac system and use the exchanger from that as the one for the awic? just thinking...
inlet and outlet are too small. It won't work. You have to buy a proper heat exchanger.
Posted: Mon Sep 24, 2012 8:26 am
by kimokalihi
It'll be more for me aince I'm buying a reservoir for mine. Extra $100 there.
Posted: Mon Sep 24, 2012 5:28 pm
Turbo_Carl wrote:inlet and outlet are too small. It won't work. You have to buy a proper heat exchanger.
Just to add to this....the AC condenser is the wrong type of exchanger for water and will have a rather large amount of back pressure...if it worked at all.
Posted: Tue Sep 25, 2012 3:22 am
by ride_child
Ahh gotcha haha just a thought! Thanks guys!
Posted: Tue Sep 25, 2012 4:45 am
by martimus919
Nice work! Subscribed
Posted: Tue Sep 25, 2012 8:03 am
by Turbo_Carl
Well it's all installed. System was very easy to bleed with that extra filler cap.
Did a stress test at 15psi (don't go that high unless you have an upgraded fuel system) drove for 20 mins and the intercooler was ICE COLD when I pulled over to check it.
ICE COLD
I consider this install a great success! Everything works PERFECT!
Full video to be released tomorrow. I made a few mistakes on the install and had to backtrack, and ya'll are lucky because I will explain everything to look out for and expect.
Posted: Tue Sep 25, 2012 10:16 am
by kimokalihi
Awesome!
Posted: Wed Sep 26, 2012 3:32 am
by beatersubi
Any way to test pre- and post-intercooler temps?
Posted: Wed Sep 26, 2012 3:50 am
by kimokalihi
I've already ordered my probes and multimeter setup specifically for that but I won't have an awic for quite some time.
Posted: Wed Sep 26, 2012 3:51 pm
by cj91legss
Turbo_Carl wrote:Well it's all installed. System was very easy to bleed with that extra filler cap.
ICE COLD
Alright, Lets get that info!!!
Posted: Wed Sep 26, 2012 4:46 pm
by James614
I'm curious to see the before/after temps, and how they compare to the performance we've seen from WRX TMIC's.
Posted: Thu Sep 27, 2012 7:29 am
by kimokalihi
Got my temp probes and multimeters today and installed them. Check it out here:
http://bbs.legacycentral.org/viewtopic. ... 39#p390239
I don't have the AWIC yet but this gives a good idea what the WRX TMIC is like. Keep in mind I don't have a splitter or any type of intercooler ducting but I might get one soon.
Posted: Thu Sep 27, 2012 3:40 pm
by James614
I've seen before that pre-intercooler temps can be close to 300*, but it's just so crazy to imagine that and then see turbocharged (and supercharged) cars stock with no intercoolers!
Posted: Thu Sep 27, 2012 8:38 pm
by kimokalihi
I'm guessing the cars that are stock with no intercooler must not be creating as much heat. I can't imagine blasting 250+f air into your engine.
Posted: Thu Sep 27, 2012 10:21 pm
by James614
I've seen on here before from someone with a VF-11 and no intercooler, and the temps were right around 250 max if I recall correctly.
Posted: Thu Sep 27, 2012 10:27 pm
by Turbo_Carl
Sorry for the delay on the vid. Mixture of editing software not cooperating and being stuck at work too much. I saved the full vid last night and will post to youtube today.
Posted: Thu Sep 27, 2012 10:58 pm
by kimokalihi
Patiently waiting for video.
Posted: Fri Sep 28, 2012 12:48 am
by Turbo_Carl
kimokalihi wrote:Patiently waiting for video.
about an hour left on the upload
Posted: Fri Sep 28, 2012 7:57 am
by Turbo_Carl
Posted: Fri Sep 28, 2012 10:03 am
by kimokalihi
Watched it probably 3 hours before you updated your thread haha. Thanks for the info.
Posted: Fri Sep 28, 2012 6:30 pm
by SILINC3R
Nice video and it looks great would like to do that but I want to keep my A/C as it's hot as shit here is Alabamer.
Posted: Fri Sep 28, 2012 6:48 pm
See....the folks up in the PNW think it's no big deal to pull your AC
Come live down south and you'll want to put extra AC in
Posted: Fri Sep 28, 2012 7:07 pm
by Turbo_Carl
All it requires to keep A/C is a smaller heat exchanger really. That's it. The compressor and a/c lines had no effect on the placement of the Intercooler or water lines. The only option from silicone is to run two heat exchangers in series. Which that bosch pump will have no problem with to be honest. I will swing by silicone intakes and make a vid in a couple days to show how to do it.
Posted: Fri Sep 28, 2012 8:41 pm
by James614
Just want to point out that if you pull your A/C system, your A/C button works as a radiator fan switch, handy for when you want to cool the system while sitting (between Auto-X runs, for example). I almost bought and installed a dedicated switch for the fans before I realized this. If you drag race or auto-x you'll definitely want some fan control.
Posted: Fri Sep 28, 2012 11:54 pm
by Turbo_Carl
James614 wrote:Just want to point out that if you pull your A/C system, your A/C button works as a radiator fan switch, handy for when you want to cool the system while sitting (between Auto-X runs, for example). I almost bought and installed a dedicated switch for the fans before I realized this. If you drag race or auto-x you'll definitely want some fan control.
I was first considering using the A/C as the switch for my pump, but decided to go with a dedicated switch to be safe.
