turbo970's 92 tw rebuild with updates
turbo970
Re: turbo970's 92 tw rebuild
Post by turbo970 »
thats what he said that was causing the binding. i'm already pricing out reman'd trans.
turbo970
Post by turbo970 »
well he said he was ordering a low mileage trans from a jdm import shop out of texas. he wants me driving my car finally by the end of the month . fingers are crossed
turbo970
Post by turbo970 »
turbo970
Post by turbo970 »
jdm trans didnt work because he said it was too new ie from a 97. so we sourced a reman one from portland. should be here and in the car by next friday. keep ya fingers crossed. this has been a long and stressful process.
turbo970
Post by turbo970 »
http://www.portlandtorque.com
this is the shop i'm getting my trans
Their site and info on the site looks to be good and would be a reputable shop.
turbo970
Post by turbo970 »
the trans has a 5 year 100,000 mile warrenty
turbo970
Post by turbo970 »
well the trans shop in portland didnt work out. local trans shop is working on it. the hold up has been the torque converter
Damn it! What did they say about the torque converter?
turbo970
Post by turbo970 »
it was shot and i guess there were options. there was type of color code and the one on mine was either warn off or faded
turbo970
Post by turbo970 »
still waiting on a torque convertor. does it really take this long to get one
No it shouldn't. Sounds like someone dropped the ball, like promised the tranny shop something they didn't have.
turbo970
Post by turbo970 »
i finally get the subie back monday or tues day. i saw my freshly rebuilt trans today. fingers crossed
turbo970
Post by turbo970 »
minus a trans mount the subie is done. i get to pick it up tomorrow finally lol
turbo970
Post by turbo970 »
drove the subie yesterday. pulls good. but still idles high and shifts at high rpms. they pulled the codes and the new tps is bad. so they ordered one and will be here friday.
turbo970
Post by turbo970 »
well good news and bad news. good news i got my subie back today. its drive able but not perfect. the replaces the tps and fix the wiring at the plug for the tps but the idle still high then low. and shifts at 5000 rpms . he said to try a another tcm
CAV3MAN227
Post by CAV3MAN227 »
-Wow, what a trip you have been on. I'm impatient and I would have been pissed! Hope you get it running correctly.
-Joe
turbo970
Post by turbo970 »
well i'm looking online for a tcm. i can drive it if i shift it manually
turbo970
Post by turbo970 »
pulled 2 codes from the tcu 31 and 32. i know the 31 is the tps and its new and set right but still have a high idle. code 32 is the vss 1 if i remember right. my speedo works but the shift points are way off. would a bad vss cause the high rpm shifts
I replied to your other two posts about VSS1.
turbo970
Post by turbo970 »
kk thanks. i gave the subie a bath today gonna take some pics too
turbo970
Re: turbo970's 92 tw rebuild with updates
Post by turbo970 »
well i waiting on the trans harness. i checked the tps with mt digital multi meter and its with in specs. the idle is still high. it will go up to 2500 then slowly drop to 1100 or so then after i it the throttle it goes to 500 and just kinda sputters with out dieing . friday i got the leak fixed and they checked the old trans harness and what ever the did made the shifts points drop to 4500 rpm. so i'm starting to thing something in the harness is messed up. but i cant get the tps code to clear no matter what i try .
robertpaige
Post by robertpaige »
God TPS issues are trending HARD!
I feel like you need to adjust the TPS again, not really sure what else. If it's not rotated right (in the right spot) it will throw a CEL. Did you line up the TPS with the white marks to the screws that hold it in?
You have been waiting FOREVER to get this thing running..
turbo970
Post by turbo970 »
theres no white marks on mine
turbo970
Post by turbo970 »
pulled the plugs today to check the gap and they were soot black. this pos is running rich. any ideas what causes a rich mixture besides the O2 sensor. and the only codes showing are the tps and VVS 1
