Actually, I was asking about discounts on OmniSoC though.
The buffered sampler thing makes a lot of sense... Basically a poor man's oscilloscope. Nice idea.
I'm not sure I understand what you mean about implementing a closed loop for the oxygen sensor... Do you mean this chip would take over the responsibility of performing fuel trims at light load?
Hey! That's a good idea! For multiple reasons! Yes. It's all making sense. When you install this chip, you should disconnect the oxygen sensor from the ECU. That way the ECU will always run in open loop so it'll run predictably. Ignition timing should also be more predictable. Then this chip can do its own closed-loop fueling under conditions specified by the tuner (basically a manifold pressure threshold and a TPS threshold, I'd think).
Ooooh. This gets better and better. You could have the switchover voltage user-specified too. Then, with a wideband sensor, you could run in closed loop all the time, not just at light loads -- you could have another 16x16 table containing desired air/fuel ratios.
Mmm. Definitely something to think about for the future.
Yes, the values in the MAF conversion table must be divided by 256 to get the airflow in grams per second. It may be useful and sensible, though, to first divide the number by engine speed, computing grams per revolution rather than grams per second.
