Color Codes *IMPROVED NAVIGATION*
originalcyn
Re: Who Wants to Play a Game? (Color Codes) *IMPROVED NAV*
Awesome, did it come that way from the factory?
No, I liked the way the second gen Outbacks looked so I copied what the factory did, and it dosn't look bad at least I like it. Also it sets it apart from all the outher white first gen legacys. In my area there are a ton of plain white ones.
Charles
I freakin like it!
originalcyn
Hmmm, we're missing both of those colors from that year. what to do...
Rallyak, The white is the original color, and you added the slate over the top?
Yes, I wanted to do a cool trick paint job but ended up using the stock white and added the gray of the same year so I wouldn't forget the paint code if or when I needed to touch up or repaint.
Charles
originalcyn
Ok, awesome. I'll just list it for both then. If anyone's concerned they can read the surrounding conversation to get the context. Thanks for posting it!
originalcyn
Re: Color Codes *IMPROVED NAVIGATION*
Rembly, if you have some shots of yours (i'm making the assumption you have a legacy) post them up! I'll edit the list to included it. The more the merrier (and more accurate).
New 94 Wagon I picked up.
Stillwater Blue Pearl - 44B
IronMonkeyL255
Rio Red '91 Legacy SS
originalcyn
Awesome, thanks! Updated the index page.
originalcyn
Misty Dawn Metallic - 059
originalcyn
Majestic Blue Metallic - 039
1992 Legacy L, Pure White code 230
originalcyn
Thanks shoefean! OP updated, 1992 60% completion.
Traded this 92 Auto...
For this 94 5 Speed!!
Color code #433, Spruce Pearl
originalcyn
Thanks again Shoefean! OP Updated.
1993 Forest Pearl Mica - 378
'93 2.2 Sedan, WRX Turbo swap running on ethanol, MT, Low Range Gear, LSD, dark green, leather
Europe, Lithuania, Vilnius
originalcyn
Thanks GedasT4! With that, we're only missing two colors from 93 to be complete! At least USDM complete. GedasT4, i noticed you're in Vilnius. I don't know which market your car is from, but i'm going to count it as USDM for kicks! Thanks a bunch!
Kijan,
I updated GedasT4's post with your hosted image.
originalcyn
Thanks Josh, I imagine that GedasT4 won't mind it showing up instead of link having to be clicked. And if it is something that he feels strongly about, he can always go in and edit the post to reflect what ever hosting he desires.
originalcyn
1992 Misty Dawn Metallic - 059
Courtesy of bmxxkelowna
legacyfrank
1993 Legacy SS (undergoing EJ20G swap)
1994 Legacy Touring Wagon (Stock)
1994 Legacy Wagon n/a X2
I've seen that same graphic on them before so I suspect it was an optional accessory.
originalcyn
Thanks legacyfrank! First post updated to reflect your post!
