Added another to the collection. (updates,SIDESWIPED!)
PhyrraM
Post by PhyrraM »
More prep for the eventual engine install.
255LPH high pressure Walbro.
I had a spare fuel pump assembly that came with a EJ20G swap. It turns out to be the exact same thing as a turbo Legacy with the exception of the low fuel sensor.
Walbro (on right) next to stock pump (left)
Ready for install. I used the '93 WRX "frame" with the Legacy float/low fuel assembly.
PhyrraM
Post by PhyrraM »
Got the pump installed. I was planning on doing a write-up, but it's so straightforward that one doesn't seem needed.
I went with the GSS341, based on old posts here on LC. It fit perfect, with zero issues.
Based on numerous posts on different forums I read in my research, I was expecting a significant increase in fuel pump noise. In my case, that didn't happen. It's barely louder than stock and with the motor running I can't hear it at all.
I also changed the fuel filter because I have no idea how old it is. It's also just common sense during a fuel pump swap. What was completely suprising, to me at least, was the amount of sediment in the old filter. Pictures can say it better then words in this case.
n2x4
Post by n2x4 »
When I pulled my spare Legacy Turbo fuel pump, I looked up the part number on the pump and saw that it referenced the JDM turbo cars.
Good build - you've got a knack for complete documentation!
SUBARUEHS Racing
Was that out of the filter in the engine bay or the filter bag on the pump suction?
dropdfocus
Post by dropdfocus »
Looks to be from the gas tank not the engine bay. Nasty stuff!
Jason
PhyrraM
Post by PhyrraM »
Nope!
That was what was actually drained out of the old fuel filter from the engine bay.
Nasty indeed. After seeing that I wished I had tested the fuel pressure before changing the filter.. Just to see how much was lost in it, if any.
PhyrraM
Post by PhyrraM »
Coming soon
My biggest experiment yet.
Image[/u]
sweet...
dropdfocus
Um, why?? For fun factor or are you intending it for handling?
Jason
This is so sick! I can't wait to hear and see some final results!!!
PhyrraM
Post by PhyrraM »
dropdfocus wrote:Um, why?? For fun factor or are you intending it for handling?
Well, I've always admired the system and was sorely dissappointed that it was discontinued before I could afford one for my '02 WRX. Actually I still couldn't afford a new one, but I got a screaming deal on this used one.
I've read all the "bad" reviews, and the good ones. Most of the negativity seems to regurgitate the comments in the old SCC article. But, once you really get into the research, you realize that everyone who actually bought it for it's intended purpose has given it a huge thumbs up. It's intended purpose being a very well rounded DAILY DRIVER, that can still be used for weekend fun. It's not a competion suspension. I don't want a competition suspension. But I do like having fun.
It's a challange. Look back to my PowerFC install on a stock wasted spark Legacy SS.
I do carry stuff in the trunk, and the self leveling would be sweet.
It would certainly be unique. I also see a hint of Subaru legacy (the past, not the car) in having a really good air suspension. While no means pioneers in the area, Subaru did stick with it longer and more often than most other makes. (Early and late 80's wagons, the XT, and the Legacy all had them as options, possibly others too)
And possibly most importantly, It was a screaming deal.
dropdfocus
The reason I ask is because I had a Air Lift Tech. bag kit on my '01 Ford Focus ZX3 a few years ago for the fun of it vs. any type of function. The Ground Control / Koni setup I had prior was great & I should never have gotten rid of it. :(
I'm also avid "mini trucker", so airbags systems are all too familiar to me. I know that Air Ride Tech. has done some great things with airbag kits on old muscle cars and made them handle very well because of it.
Best of luck to ya in your on going project. 8)
Jason
PhyrraM
Post by PhyrraM »
Ah, well if you've never looked into the Praxis, yes, it was designed to be a handling suspension. It's claim to fame was the ability to properly increase springrate as the car dropped, all from a dash mounted switch. The downfall was you had to manually go and adjust the shocks to match the new springrate using a knob on the bottom of the shock.
So, 3 settings. "Touring"- close to stock height and springrates. "Sport"-1 inch drop, extra fun on the street 250ish springrate. "Track"- 2 inch drop, track use only, 350ish springrate.
With proper alignment, it worked well. The sole engineering exception is that Subaru designed the rear suspension to toe-in under compression (drop). This makes the starting alignment very critcal and even at that a noticable comprimise.
I think most of the "bad press" comes from people thinking it could be a true hardcore track suspension AND a stockish daily driver. That's asking for built in dissapointment. I also think that having to leave the car and get on the ground to adjust shock valving turned a lot of people off. I'll bet they had visions of "dropping to race mode and pulling that freeway cloverleaf on-ramp", then going back to cruise mode. You can do that, but without changing the shocks to match (because your already rolling away from the light) your "now low and stiff" springs are woefully underdamped because your shocks are still set at "stock and high". Can you say "bouncy and bottoming-out POS"?
If you can't tell, I'm still talking myself into it, even though "the checks in the mail" :lol:
dropdfocus
PhyrraM wrote:If you can't tell, I'm still talking myself into it, even though "the checks in the mail" :lol:
LOLZ!!!!!!! Been there done that many times! :mrgreen:
Jason
91legacyawdturbo
Post by 91legacyawdturbo »
nice write up on the swap! I just put an ej20g in mine. how does yours run off of a stop?
2002 wrx sport wagon
PhyrraM
Post by PhyrraM »
91legacyawdturbo wrote:nice write up on the swap! I just put an ej20g in mine. how does yours run off of a stop?
Thanks. For the most it feels like my stock WRX. A little boggy until about 3000 RPM then comes on strong. I don't launch it, not my style, but I do run it to redline (currently 7K) often.
I'm currently fighting an occasional hiccup/misfire that I believe is a weak ignition. It is becoming more common the last 300 miles. But other than that, no issues.
91legacyawdturbo
nice, I had the same issue I found that I didnt have the vac lines for the fuel pressure regulator right. It was causing a low stumble off of the line (like you would regularly drive). when I first tried to start mine up the coil packs where really weak. I know mine is running alot better no more miss and it doesnt stumble any more.
PhyrraM
Post by PhyrraM »
I've got a few updates, nothing major but I figure it's easier on me to make small updates rather than larger ones.
I've got the misfires figured out. Spark plugs. When I installed the EJ20G the local parts store didn't have the NGKs I had originally asked for, so I accepted the Autolite cross-reference. They woked fine for a few weeks, but soon the misfires started. Out they came. I ordered what the 'net told me was the OEM EJ20G plug.
The Autolites after removal. They don't look bad, but the NGKs have had zero misfires since they were installed.
The NGKs in the background are OEM 100,000+ miles '02 WRX plugs.
More parts arrived for the built motor. '05 STI 550s. I already have the EJ25D rails needed to drop them into one of my EJ20G intake manifolds.
The last item I recently got in preperation for my built motor is a replacement cell phone. A 16gig iPhone 3G, to be exact. To be even more to the point, I got it to use an app called Dynoliscious. Basically it uses the iPhone's internal accelerometer to estimate acceration data. Kind of like the old G-techs used to do. I'm not looking for 100% accuracy. I'm more looking for repeatablity. It should turn into a valuable tool for tuning.
It outputs charts like these, and can even save them as pics to be exported. The yellow "horsepower" line is simply derived from the acceleration rate and the weight of the car, which is user defined. I put 3300 pounds for now.
The iPhone itself will give you estimated timeslips. It's been tested to be resonably accurate, but very repeatable with a solid, stable cradle in the car.
All the above "runs" were done very impromptu, with very transmission safe launches and shifts. I'm pretty satisfied with the "times", even if they are estimated. Once I get more experience using it, I'm sure it will become a great companion to the wideband, the laptop, and the PFC itself.
GodSquadMandrake
Post by GodSquadMandrake »
Wow that's cool! LOL I had no idea you could do that. Those are some pretty good numbers too.
-Doug Wilson
asc_up
Post by asc_up »
Awesome. I have the same program, but my numbers seemed a bit skewed. I think my phone kept sliding around. Do you have a mount for it?
Did it show any performance difference between the Autolites and the NGKs?
dropdfocus
Personally, Bosch and NGK are some of the best plugs out on the market. NEVER use Champion on anything you care about, and Autolites are ok in a pinch. I've worked in garages & seen the end results of these plugs! Don't go cheap if you can avoid it.
Jason
PhyrraM
Post by PhyrraM »
I was trying to wait untill I cleaned up the dash to post my cradle, but oh well....You asked. :lol:
I went with Pro-Clip. As far as I can tell they are the only ones to still be making a custom fit cradle mount for the BC/BF. It clips between the vent and the dash trim, but it's very secure and rigid. You can use any cradle on the mount, but I chose a slightly oversized, adjustable one because I'm very rough on phones and am going to need a fairly tough, oversized case. (Like this)
As far as the plugs go, I never noticed a difference in the feel between the Autolites (untill the misfires) and the NGKs. I didn't get the phone untill after the NGKs, sorry. I wasn't too happy about having to buy the Autolites, but the parts store and I have a good relationship and I trust them to make a reccomendation occasionally. This time they were wrong, but that's the exception.
dropdfocus
I used to have something exactly like that in my Focus ZX3 years ago. It was real nice for hands free speaker phone.
I'll have to look them up on the Internet.
Jason
SLODRIVE
Post by SLODRIVE »
VERY cool phone mount...I may have to get one of those. Too bad there's no app like that for my Tilt.
http://www.slodriveracing.com
-And more!
