Back with more progress/upgrades...
I swapped the Turbo wheels for WRX 16s with 205/55R16 Winterforce tires, and I think it looks a lot better. Even with the crappy rattle-can paint job, this car's beginning to look a little mean. It's starting to get a few looks from the ricers on Main Street.
I also took some steps to open up the exhaust. Thanks again to Craigslist, we came up with an "Ebay" 3" midpipe and a Perrin 3" axleback with twin tips for a total of $225.
Here's the Perrin after relocating the LR hanger to fit the Legacy, sitting next to the OEM WRX axleback...lol.
...And here it is on the car. The extension I slapped into the front of the mid-pipe is where the cat will go...it should get here tomorrow, and I'll add a couple more hangers then too.
After driving around with this exhaust setup for a while today, I can say two things for sure: The car's
noticeably faster, and it's much louder...as in, it sounds a lot like Rob's modded STi. There was also more boost right away, as in it pegged the 15lb. gauge the first time out. I turned the boost down to about 12 from around 14 pounds, and it still feels faster than before the exhaust swap. Again, it's
LOUD though...I hope the cat mellows things out a little bit. I kinda doubt it though, haha. No carpet or sound insulation, remember!
I still haven't gotten around to having some logs hosted to post up here, but I at least have a screenshot of a recent log file. The bottom half of the screenshot shows part of a 3rd gear WOT pull. One thing you'll notice is that the RPM's jump around a little on the log, we're thinking it may just be sampling errors in the logging software, and I'm not concerned with that. Also, boost pressure is measured in absolute PSI, so you have to subtract about 12.6 PSI from the pressure readings (column "K") to arrive at what I'm running for boost here at 5000ft. altitude. This is still a tune in progress, but it's getting there.
