-Thanks. I just found these metal pieces in my shed, cut them and drilled some holes. The alignment was perfect for holding the tank. I used one of those rubber/metal grommets you can find on the 02 wrx tmic brackets as a spacer on one side to level the tank out. The tank looks to be higher than the turbo. If not, I can swivel the brackets around to bring the tank up higher.Legacy777 wrote:Looks good! Like I said, I like how those tanks fit in the spot where the AC compressor sat.
-Joe
