Page 7 of 8
Re: turbo970's 92 tw rebuild with updates
Posted: Tue Jun 11, 2013 3:55 am
by turbo970
well i know they tried a tcu out of a subie they had there for parts and still did the same thing. the owner said the ecu tells tcu when to shift. they spent 4 days checking all the wiring and re checking the wiring it all tests good. so if the ecu dont's work i'm selling the car
Posted: Thu Jun 13, 2013 2:30 am
The ECU doesn't tell the TCU when to shift. The TCU controls the shifting by itself. It receives certain inputs from the ECU or other sensor, like engine rpm, vehicle speed, and throttle position. Other than that, the TCU does its own thing.
I completely understand your frustration.....wish you could find a shop that could properly diagnose the problem.
Posted: Thu Jun 13, 2013 5:18 am
by turbo970
i'm out of money. if the wiring is good sensors are new then it should shift right. they tried a another tcu and still did the same. none of the codes will clear. still has a tps code maf code vss 1 code and o2 code. i tried all day to clear them just like your print offs said to do and nothing worked. if the new ecu doesnt help i'm done
Posted: Thu Jun 13, 2013 1:31 pm
by SILINC3R
If you have a code for the TPS make sure to is all the way seated and your are geting proper readings at the plug. Had mine unplugged and started having tranny problems.
Posted: Thu Jun 13, 2013 6:16 pm
Are there any members nearby that could look at it, or have you already been down that route?
Posted: Thu Jun 13, 2013 7:05 pm
by alexandermf
The best thing I could recommend is towing it to Greg at Slodrive... Maybe save some money up for it and everything, I've been through this same problem and spent over 1300$ and two months at a shop that couldn't fix it... Towed it to gregs and had it fixed it under a day at a fraction of what I had paid
Heck I ALMOST flew josh from Texas out here to fix it before I was referred to Greg who was local at least
Posted: Thu Jun 13, 2013 7:32 pm
I would second Alex's recommendation....if you have the time and money to get it to Greg for him to look at, that's probably your best option.
Posted: Thu Jun 13, 2013 8:37 pm
by turbo970
i dont have that kind of money 2500 in the motor 2300 in the trans rebuild i'm tapped. and alex's ecu didnt work. i'm done
Posted: Thu Jun 13, 2013 9:19 pm
by alexandermf
Ugh I hate these electrical diagnosing problems.... I almost threw the towel in too and almost sold/parted the car out, but I borrowed a car for a month from a family member and saved up to take it to Greg and hasn't broke since then... It sucks but these issues some shops/people just cannot fix. Even Chris(92coloradosubie) or whatever it is blew his engine and had to borrow money from rents and use a car for a month plus and he's going up to gregs on Thursday finally. Your car is def worth fixing with all the money you have into it recently, if your tapped now hit up a family/good friend for a loan possibly or borrow/rent a car cheaply until you can save enough
Posted: Thu Jun 13, 2013 9:20 pm
by turbo970
i borrowed 6000 just to get this far i'm done
Posted: Wed Jun 19, 2013 9:47 pm
by turbo970
well another ecu is on the way. still getting tps code on both the ecu and tcu. the idle is bouncy and running rich. but not super rich. the shop thinks the circuit that controls the tps is toasted
Posted: Thu Jun 20, 2013 12:54 am
by robertpaige
You will get a TPS code if it is not adjusted right. Have you adjusted it to FSM Spec? I highly doubt the TPS circuit is bad.
TCU won't have a TPS code, so i'm not sure what you meant there.
Since youre so far into the car with money, I wouldnt give up just yet. There A LOT you can do to troubleshoot that doesn't require money, or little of it.
Posted: Thu Jun 20, 2013 1:05 am
by turbo970
tps is with specs using a multi meter. the tps is tied into the tcu and it does show a code for tps. it idles at 2200 rpm runs a lil rich and the shift points are way high. all sensor under the hood are new. wiring under the hood to all the sensor are good. and the wiring from the ecu to the engine bay is good.
Posted: Sat Jun 29, 2013 5:40 am
by turbo970
well next week i'll decide if the subie stays or goes. new ecu is in car runs. still getting a tps code still wont shift. still has a high idle. they want to check the timing and the harness for the tps. if those are still good and still running crappy then i'm done. if some one in colorado wants to buy it then i'll let ya know next week.
Posted: Sat Jun 29, 2013 9:36 pm
by turbo970
i'm wondering if i should take the subie to the trans shop. this thing has some nasty torque bind i just use it to go to the local store and thats it. i mean if you paid 2300 for a trans rebuild it should work right. hell should i try a tcu with this new ecu?
Posted: Sat Jul 06, 2013 1:42 am
by turbo970
well the subie maybe up for sale tuesday. the shop said they put enough time and effort into the car and they plan to give up monday. the dash is torn out and checking all the wiring from the fire wall to ecu. they did noticed some one did a hack job installing a car alarm.
Posted: Sat Jul 06, 2013 11:41 pm
Unfortunately, it's those hack job wiring jobs that just cause so much problems later in a car's life
Posted: Sat Jul 06, 2013 11:45 pm
by turbo970
well if they cant fix it then the car gots to go. i did find a complete car harness from a 93 for cheap but i dont have the time or know how to do it. this is the last straw for this pos
Posted: Wed Jul 17, 2013 2:54 am
by turbo970
Posted: Wed Jul 17, 2013 5:55 am
by CAV3MAN227
-May I ask, where did you pick up that intake elbow brand new?
http://i1018.photobucket.com/albums/af3 ... 111012.jpg
-Joe
Posted: Wed Jul 17, 2013 4:41 pm
by turbo970
diesel devil can get them in Canada. the shipping down here is pricey tho
Posted: Thu Jul 18, 2013 2:31 am
by CAV3MAN227
^Okay, I'll just have to mod my Apexi intake then... like I have to mod everything else!
-Joe
Posted: Thu Jul 18, 2013 3:47 am
by turbo970
mine was 80 shipped i think plus he did up a coffee cup mod for me
Posted: Fri Jul 19, 2013 8:40 am
by turbo970
well i got the subie drive able finally. still got to set the tps because the idle is high and if i floor it it wont kick down a gear it just slowly gets up to speed unless i manually down shift. but hey i'm happy i can drive it finally
Posted: Sat Jul 20, 2013 8:51 pm
by turbo970
its been driven the subie and i like it. its not the fastest thing but it goes. if i need to pass some one i drop it into 3rd and hold on lol
