Florin's 91ss w/ a little MAKEOVER ==> All Black Update pg.8
Re: Florin's 91ss w/ a little MAKEOVER ==> Now Build Thread
Hmmm... So you're running rich too huh? Because idle should be like 16:1 + no?
Oh and when i get into boost at wot, she puts out some black smoke too...
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Damn, got your powerstroke mod with a programmer?
i would expect idle to be from 14 to 16 any where in there would be normal.
i dont have plates on my car so i cant really drive it. pgp saturday will be my test of how it is driving
Idle ideally should be right at 14.7 to 1. That's stoichiometric fuel ratio, or the optimal ratio for gasoline to burn the most effectively/efficiently. Mine idles right about there, it fluctuates between probably 14.5-15. Cruising is also the same. It shouldn't be idling at 16 to 1.Florin1 wrote:Hmmm... So you're running rich too huh? Because idle should be like 16:1 + no?
Maybe BMX is on to something. Are your injectors in properly with good O Rings? Couldn't hurt to replace the rings if you're not sure.
Yeah i replaced o rings kimo. I've actually swapped from my 525's to 480's and now to 440's, and its running the same. Rich. I've also tried a different maf, and a diff jdm ecu, and no change. Gonna try another NB o2 sensor next.
Logan, how did ur car do at pgp?
Fuel pressure regulator? or temp sensor, just throwing things out there I dunno.
Fpr is good. Haven't tested the CTS
In the words of Jay-Z "All black EVERYTHING" hehe
So time for a little update, now that i feel a little better about the car. Finally got it running right. Got all the trim painted. Also painted the window trim, and door handles. And the tail lights. Also rolled my rear fenders further, swapped on the FHI 4 pots instead of the brembos, and got a different exhaust.
And a little editing.
Re: Florin's 91ss w/ a little MAKEOVER ==> All Black Update
Looks sick Florin. Our cars look very similar aside from the color.
Looks great Florin! Keep it up!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
O.o And it was looking so good too.... What happened?
Are you serious?! That sucks! Yours was one of the cleanest on here! Im sorry Florin.
1994 Legacy Touring Wagon
gotta pay to play when going to drift event unfortunately
That's terrible news Florin! You finally tracked down your fueling issue and had it running well? If it happened at the event, I assume you are SOL for insurance?
-Rob
-Rob
Yeah SOL. haha. Oh well. I guess its just a dedicated track car now... Rob, Yeah the car runs great now. Pulls hard. Right into walls!
Yeah, I'm alright. Neck is a little sore, but not a big deal.bmxkelowna wrote:
not good man you alright?
You gonna fix the body or get a na and swap?
He's already got another SS if he wanted to swap but I think he's just going to track it.
just saw this on northwestnissans. that wall comes up hella fast after the 3/8th bank for sure
Yeah it would be too much work to transplant everything into an n/a. And even if i was to swap everything over, it would be into an impreza two door.
Hey Logan thanks for the picture. I was wondering when i would see some pixels show up. I've been looking but haven't seen any. I would love to find a video too.
