94SS_Canada
Posts: 851 Joined: Mon May 12, 2008 4:19 am
Post
by 94SS_Canada » Wed Oct 15, 2008 5:26 pm
dzx wrote: oh, when you do the timing belt, make sure you line up the mark on the back of the crankshaft pulley, on one of the teeth that triggers the sensor, and not the arrow on the front of the pulley which indicated TDC. This can trick people.
I thought the crankshaft pulley only went on one way?
I just put it on, torqued it and thought i was good.
I know i did a hack job of converting the tps to the 2.5 one but im going to use a 2.2 one and do it right, ive talked to a few people and even with a bad TPS it still should start could it not be starting because my lack of an IACV with a bad TPS?
FastRust
dzx
Posts: 2711 Joined: Wed Aug 04, 2004 3:52 am
Post
by dzx » Wed Oct 15, 2008 7:06 pm
The crankshaft pulley only goes on one way. But there are two marks on the pulley. One is for TDC and the other is the timing mark. make sure you have the right one lined up. When my tps had a few broken wires, it still started up. It just bogged when you gave it throttle.
///M
'93 Legacy SS - part out
94SS_Canada
Post
by 94SS_Canada » Wed Oct 15, 2008 10:05 pm
ill go take a look..thanks..
FastRust
Gord.
Posts: 10 Joined: Fri Aug 29, 2008 6:00 am
Post
by Gord. » Wed Oct 15, 2008 10:14 pm
It's good to see that you havn't given up on the project. It's so close it's just down to ttroubleshooting now.
94SS_Canada
Post
by 94SS_Canada » Wed Oct 15, 2008 10:19 pm
tell me about it, so close to giving up....so lazy....no money..
FastRust
Gord.
Post
by Gord. » Wed Oct 15, 2008 10:40 pm
do you know how much you have into the project?
94SS_Canada
Post
by 94SS_Canada » Thu Oct 16, 2008 1:27 am
1200$ moter
150$ FMIC
165$ Turbo
120$ intake
80$ intercooler pipes
150$ Downpipe
80$ exhaust
headers, oil line, coolant lines 180$
Suspension 200$
the car 1500$ (with a running moter)
Fuel pump 130$
injectors 90$
Random bits 150-200$
Roughly, 4,285$
But probally closer to 4800$ total...
Also i just looked at the crank and i cant find those marks your talking about?
FastRust
Gord.
Post
by Gord. » Thu Oct 16, 2008 4:04 am
still under $5000 is pretty sweet for what you end up with
Gord.
Post
by Gord. » Thu Oct 16, 2008 9:25 pm
it will run
94SS_Canada
Post
by 94SS_Canada » Thu Oct 16, 2008 11:26 pm
Gord. wrote: it will run
I HOPE SO, IVE been trying and trying!
FastRust
Posts: 3043 Joined: Tue Jan 25, 2005 9:14 pm
Post
by 93forestpearl » Fri Oct 17, 2008 1:56 am
What are you using for management?
stipro
Posts: 699 Joined: Mon Apr 26, 2004 4:20 am
Post
by stipro » Fri Oct 17, 2008 3:05 am
He is using the stock EJ22T ecu.
94SS_Canada
Post
by 94SS_Canada » Fri Oct 17, 2008 4:19 am
stipro wrote: He is using the stock EJ22T ecu.
For now.
ASlo STIpro did you read the post how i got rid of that cam gear sensor code?
Also i just re-sodered my old TPS connector on with a picknpull throttle body, TO get rid of that last code...
FastRust
dzx
Post
by dzx » Fri Oct 17, 2008 6:32 pm
so you're getting no codes now?
///M
94SS_Canada
Post
by 94SS_Canada » Fri Oct 17, 2008 7:00 pm
dzx wrote: so you're getting no codes now?
Hopefully when im done with the Throttle body i should be getting no codes now.
FastRust
Gord.
Post
by Gord. » Tue Oct 21, 2008 6:16 am
any news?
94SS_Canada
Post
by 94SS_Canada » Tue Oct 21, 2008 6:28 am
Ive had a long weekend.
Didnt touch the car.
FastRust
94SS_Canada
Post
by 94SS_Canada » Wed Oct 22, 2008 9:52 pm
Alright
So sodered in Pick-N-pull EJ22 Throttle Body (Sodered TPS wires and attatched throttle body)
Charged battery.
Try to start it one loud bang of a backfire and then nothing but slow cranking.
I plug in the black test mode connector and turn the key to ON.
Instead of getting a series of code the CEL just blinks and blinks dosent stop repeat or do anything that Legacy777's site says, just blinks. What does that mean?
FastRust
Posts: 3242 Joined: Mon Oct 16, 2006 9:44 pm
Post
by ericem » Thu Oct 23, 2008 12:57 am
There are no codes.
94SS_Canada
Post
by 94SS_Canada » Thu Oct 23, 2008 6:22 am
So Ive eliminated all the codes and it still dosent start.
God hates me.
FastRust
94SS_Canada
Post
by 94SS_Canada » Thu Oct 23, 2008 6:28 am
If it wont start im taking it to my friends house leaving it there and buying a beater car, done and done
FastRust
94SS_Canada
Post
by 94SS_Canada » Thu Oct 23, 2008 10:51 pm
Ive hit a brick wall.
Its getting towed to a friends acrage where i can work on it and do it right when i have the money, for now im getting a beater car.
FastRust
94SS_Canada
Post
by 94SS_Canada » Sat Oct 25, 2008 5:57 am
So ya got a 79 BMW 528I runs like a dream, 400$
This project is not over!
It is on HOLD!
Thanks to anyone whos helped me up to this point, hopefully look forward to some updates in a couple months.
FastRust
dzx
Post
by dzx » Sat Oct 25, 2008 7:09 am
if it backfires, it's the timing, simple fix just get it right.
///M
