Page 9 of 28
Posted: Wed Jan 28, 2009 6:26 pm
by Adam West
Interesting - thanks guys.
I'll have to ping them to find out if the chip will work with the MBC...smartly I ripped out the stock system a while back...
I may make the trip up there this Spring and get tuned on a chip just for my set up and call it good.
AW
Posted: Thu Jan 29, 2009 1:06 am
by skid542
Adam, if you're going to spend the money on getting the chip and you've already dropped the money you have for a good turbo and setup - just buy another boost control solenoid and pressure sensor. The boost will be controled much better through the chip than with your MBC and you'll net better results. You've gone a long ways not to half ass your mods so far, don't start now
You may be able to use WRX components, but I'm not positive on that.
This is all assuming you didn't rip out the wiring harness and instead just pulled out the components.
Posted: Thu Jan 29, 2009 2:44 am
by Adam West
I guess I never thought about it but I am a cheap shit...except for my car <grin> No, I was under the impression that the stock boost system couldn't handle higher boost levels but I guess that's not quite right...if the ECU is telling it to boost higher then it will do so and do so more accurately? This is a bit of paradigm shift for me I guess...Wonder what I did with those stock parts???
Keep the input coming!
Sure would be fun to run antilag and shoot fire out of the tailpipe but I doubt I'll ever be that into it.
Cheers!
AW
Posted: Thu Jan 29, 2009 4:37 am
by BSOD2600
Adam West wrote:Iif the ECU is telling it to boost higher then it will do so and do so more accurately?
This is mikes reply from a simular question I had
The ECU's boost control algorithm allows for a much faster spool-up than the MBC. Basically, you can think of it as a variable MBC. We've set it up so that under full throttle, the ECU will "crank up" the duty cycle until boost target is reached.
Also, they've set up a forum
http://forum.revtronix.com
Posted: Thu Jan 29, 2009 2:04 pm
by BXSS
+1 I got a E-mail from Mike @ Revtronix with the forum link!
Posted: Thu Jan 29, 2009 11:09 pm
by ScottyS
Yup, I'm on the forum.
Posted: Thu Jan 29, 2009 11:14 pm
by Adam West
Thanks for posting - just joined. Also, FYI I got something from PP today. They have new US distribution here...
http://www.perfectpowerusa.citymax.com/ ... 995627.htm
Posted: Sun Feb 01, 2009 10:04 pm
by RJ93SS
got stage 1 in right now. so much smoother and so much quicker.
i can't wait for stage 2
to be properly done because that's what will really pump her up. it's putting out 11-12 psi right now.
stage 1 doent even use an intercooler and it's setup for the vf11
Posted: Sun Feb 01, 2009 11:09 pm
by BSOD2600
RJ93SS wrote:got stage 1 in right now. so much smoother and so much quicker.
Got any data to back that up?
By the seat tuning and performance analysis is... quite subjective.
Posted: Mon Feb 02, 2009 1:29 am
by RJ93SS
BSOD2600 wrote:RJ93SS wrote:got stage 1 in right now. so much smoother and so much quicker.
no, i dont have any data until you come up here so i can blow the doors off you
just kidding. if someone was willing to hook up 80cdn i would go have it dyno'd with and without the chip though.
i'm not bullshitting, if it was shit i would tell you guys it was shit. but it's not and it feels alot better.
me and my dad found and open stretch of highway the other day. he's got a 92 tw. were both i/c'd, exhaust ect.ect. he's got 112k i got 130k, he has a td05 i got the 04, he's 8lbs wastegate, i'm stock. oh yeAH AND I AM 120 LBS HEAVIER THEN HIM. SORRY for the caps.
anyways we both punched it at the same time and i pulled a little faster and crept ahead a couple lengths. now that i'm chipped, i have full confidence that i would slaughter him. however if he gets chip'd, i think i'll be going into hiding until i find another turbo
Posted: Mon Feb 02, 2009 4:30 am
by Subaru_Nation555
Any comments on MPG with the stage 1 chip?
Posted: Mon Feb 02, 2009 5:37 am
by RJ93SS
i tested right before i got the chip, i see about 365km per 50 liters, not very good. i'll have chip results sometime soon
Posted: Mon Feb 02, 2009 6:53 am
by RJ93SS
just got back from picking up the wife and just wanted to say how much smoother the car drives, it feels like the new wrx i tested the other day. smooth and fast. i think i hit 100 in about 6 seconds now. i'm going to give the chip back soon and patiently wait for the proper stage 2 i should be using. i'm scared i'm going to blow my 17 year old 4eat to hell
TD04 Testing update
Posted: Tue Feb 03, 2009 5:14 pm
by wtdash
I'm scheduled to get the Stage 2 - TD04/TMIC/440cc/etc tune this weekend........
HOWEVER, I'm having an undiagnosed boost issue that will likely make the tune applicable to only my car.
I just discovered that I'm already running the newer/lighter spring TD04 Wastegate Actuator and still getting 12 psi @ the WG (should be <10 psi)....so Revtronix won't be able to use mine as a tester.
UPDATE -02/09/09: Mike @ Revtronix now thinks this is common w/the EJ22T/ TD04 and larger exhaust/downpipe.
If you have any suggestions, please see my new Thread
HERE.
Posted: Wed Feb 04, 2009 4:13 am
by skid542
I'll be curious to see how this works out for you and what they can do to work around the overboost issue. I still think your chip should be representative of what the stage 2 chip will offer due to the fact they'll still set it up to run the same boost levels. They're just going to control it a little differently.
Are you still going to go the dyno afterwards?
Posted: Mon Feb 09, 2009 2:11 am
by willstang60
Does anyone have idea when the stage 2 chip will done. And can anyone post their website . Thanxs
Posted: Mon Feb 09, 2009 6:26 pm
by RJ93SS
all i'm going to say is
sti killa
Posted: Mon Feb 09, 2009 6:49 pm
by Adam West
Posted: Mon Feb 09, 2009 8:21 pm
by skid542
Todd, how the tuning go this weekend? Were you able to make it up?
Posted: Mon Feb 09, 2009 8:42 pm
by RJ93SS
mike threw some numbers at me, they finished it but forgot to tighten down the i/c to throttle body clamp and were seeing around 14 psi, mike said dyno results on the 14psi were
180whp / 205tq. that being said, sti's put down 180-200 whp on the same dyno!
with the hose clamp tight at 16.5 psi i think the stage 2 guys will be taking on lightly modded sti's.
i'll let mike chime in on more details, i'll have stage 2 soon
Posted: Mon Feb 09, 2009 10:29 pm
by wtdash
RJ beat me to it.
The Stage 2-TD04 chip is about 99% ready. Mike wants to finalize some settings w/another guy running a TD04.
I will add that my car is running well and quick.
Posted: Mon Feb 09, 2009 10:33 pm
by ScottyS
Looking forward to it!
Posted: Mon Feb 09, 2009 10:51 pm
by RJ93SS
wtdash wrote:RJ beat me to it.
im that other guy,
thanks wtdash, you came along way to help mike and the community with this chip
Posted: Tue Feb 10, 2009 4:49 am
by smh0101
Holy shit! For real????
Posted: Tue Feb 10, 2009 11:48 am
by BSOD2600
RJ93SS wrote: mike said dyno results on the 14psi were
Those STI numbers seem a bit on the low side, since a 2008 STI is suppose to make
305hp@6000rpm. Granted, that's not WHP, but even still... Examples of dyno charts:
- Stock WRX STi dyno figure with graph (ok, missing graph, but users stating 260whp on 91 octane).
- PERRIN 2008 STI Dyno Results 230 whp, 270 ft-lbs.
- 2008 Subaru Impreza Wrx Sti Baseline Dyno Results 223 WHP 250 TQ.
