[FS] Euro glass headlights
Re: [FS] EDM glass headlights
Ooh perfect, thanks!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
'91 Black SS - SOLD
I'm getting these. who's ready?
Ben
93MY EUDM Legacy EJ22
I need post facelift corners.
If I need to buy a spare set of headlights to get them, I will.
But please let others that don't have a set at all have first grabs.
^ Lol
So since it doesn't have a matching passenger light, What kind of deal would you cut me?
That headlight will get a matching companion soon!BiNiaRiS wrote:
That lone pre-face headlight looks so sad.
Ben
That lone headlight looks like it has a tint to the lens. Is it tinted? It reminds me of the jdm headlights for the second-gen legacies there. The first two or three years had clear lights and the remaining years had tinted lights (headlights and taillights). (But what was strange is that the clear and tinted lights had the same stock number!)
'94 TW
No it's not tinted. Just the lighting conditions and crap phone camera
Will have all the lights at home this week so we'll see the details.
Ben
Re: [FS] EDM glass headlights set #1
sold
Ben
Re: [FS] EDM glass headlights set#2
sold
Ben
Re: [FS] EDM glass headlights set#3
sold
Ben
Re: [FS] EDM glass headlights - UPDATE big sale
If you get to my name on the list, I'll take whatever set (w/corners) that other folks don't want. I already have adjusters that look like they can bolt to any of those sets.
To others: this is by far the best lighting upgrade for these cars. Use with a proper incandescent bulb and the pattern is near perfect with almost HID cut-off and no dangerous "HID kit" glare.
Phyrra, for my benefit and others, what bulb would you recommend (I have post facelift lights)?
'94 TW
For stock wiring harnesses use a stock wattage bulb. I personally prefer Sylvania Xtravision 9003.
9003 is the same as H4, fyi
For upgraded harness, you can use a higher wattage bulb such as : http://www.rallylights.com/h4-12v-osram ... y-use.html
Also, on this page : http://www.danielsternlighting.com/prod ... ducts.html
Scroll down to H4 bulbs and read about the +30 and +50 bulbs. More light, same wattage, less life. I have personally not tried the "+" bulbs, but I plan to.
There is no list so far. First come first served.PhyrraM wrote:I need post facelift corners.
The corner lights are hard to get lately and the prices going crazy like $30 a piece.
I have some spare corners but not in best condition. I can send you their pics if you are interested.
And btw it's not that easy to convert from manual to electric adjusters. You need to remove the glass and modify the ball joint.
Ben
I run Hella 55w/100w, and am very happy with them. They're p/n HL78158, if you're interested.93Leg-c wrote:Phyrra, for my benefit and others, what bulb would you recommend (I have post facelift lights)?
Thanks, beatersubi, having really bright high beams would be a plus!
And, someone, correct me if I'm wrong, but the edm lights have metal reflectors instead of usdm plastic ones so the higher wattage won't melt them if used for an extended period of time, correct?
'94 TW
Hey. Im pretty new to legacies. I have a 97 GT wagon. Any difference in the factory lights and these? I believe it's a bk? The headlights at the bottom look the same as the stock ones. Thanks.
Well the headlights on that picture are from European market. They are glass and have separate parking lights in them called "city lights".
Ben
First of all: Welcome to Legacy Central!
The bottom set of lights should fit your second generation Legacy. What I don't know is if the light bulbs and connectors are the same as yours or not. Someone else will have to pitch in here. However, if the bulbs and connectors are not a direct bolt in, you can modify your harness and use the appropriate bulbs. (I'm not referring to the city lights since they are "extra" lights that the USDM OEM lights did not have.)
'94 TW
Thanks guys!
Awesome. The city light is something that will be wired in for sure, correct?
And how much will a set of these bad boys cost shipped?
