Joe's 93 RHD Legacy Wagon Build
Sublimejoe
Re: Joe's 93 RHD Legacy Wagon Build
Post by Sublimejoe »
Thanks dude! I owe it all to my wife though, I would've just complained on the internet had she not stepped in.
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
Sublimejoe
Another piece to the puzzle. NOS molding from the U.K.
Allen head bolts to replace all the mismatched bolts in the bay. Black with black washers
Parts Needed:
Manual Cluster
I removed the img tags from the pictures since the pictures were huge.
Sublimejoe
Ok is that better? I made them the large versions
Parts Needed:
Manual Cluster
That's better :)
The trim piece looks like something that goes on a fender
Sublimejoe
It does go on a fender, right here:
Parts Needed:
Manual Cluster
Sublimejoe
Oh Shit! What do we have here!
JDM EJ20G and a fresh new hoist to drop it into the car!
Parts Needed:
Manual Cluster
You mean ej20k right? Wasted spark, 3 plug ecu, straight turbo inlet under the manifold, etc.
Sublimejoe
I suppose you would know better. It's weird, a lot of the engine import places list the motors as Ej20g & ej20k. There is so much conflicting information too, I've seen the ej20k listed as forester and STI. Which one is it?
Parts Needed:
Manual Cluster
I see some red paint flakes on the intake manifold.
Sent from my SM-N920T using Tapatalk
Sublimejoe
I also saw that, can't tell if it came like that or someone painted it at some point.
Parts Needed:
Manual Cluster
Considering the age of the motor I would guess it came like that which would lead me to believe that's a 20k engine. BUT I can't swear to it. I bet Mike can.
Sublimejoe
Any way to tell for sure?
Parts Needed:
Manual Cluster
allnines'
Post by allnines' »
usually, a factory coating would not flake off unless oil or another fluid was allowed to remain on the surface for some time-not likely for the intake manifold-I think you should paint it "postal blue" :)
Legacys are like potato chips-you can't stop at one!
Sublimejoe
Not a hallucination:
Parts Needed:
Manual Cluster
Sublimejoe
Thanks to lots of help from Mike it has been verified that I my motor is a V4 STI! Pretty radical, now to figure out how I can get it running in the Legacy!
Parts Needed:
Manual Cluster
You just need to put your intake manifold harness on that engine and then work out all the pcv and intercooler stuff.
Sublimejoe
I think I'm gonna end up putting an Ej20g intake manifold on it
Parts Needed:
Manual Cluster
No, you shouldn't have to do that. Just your stock 22t harness.
On your 20k manifold*
Sublimejoe
cj91legss wrote:No, you shouldn't have to do that. Just your stock 22t harness.
Well my car was originally a non-turbo
Parts Needed:
Manual Cluster
I missed that part, my apologies.
Sublimejoe
I originally ordered the wrong clutch fork, so now I am trying to order the correct one. The tranny is from a 1996 Impreza, which was originally cable, but I have converted the car to hydraulic. Verifying this is the fork I would need for a hydraulic setup:
Parts Needed:
Manual Cluster
Sublimejoe
Photographed a car for a friend today at his shop and got this radical strut tower bar:
Also my new clutch fork came in. Time to install!
Rear sittin pretty:
Parts Needed:
Manual Cluster
