kimokalihi's 91 SS EJ20 Swap
I like them.
They may last longer, but rubber is fine.
I'm going to try to finally post some updates on the forum including a write-up or two on a couple mods I've done to my car. I don't have the kind of free time I used to have and these things take a lot of time to post. I have a ton of pictures to upload and most are on my PC. They probably won't be in chronological order, but oh, well.
First things first. I did not actually fix my ecu codes problem. They came back again and sometimes my car still has no power and feels like it's running on 3 cylinders even though I've confirmed all 4 are firing by removing spark to each cylinder one at a time. I originally thought this was due to a faulty coil pack but then I converted to coil on plugs from GD WRX and the problem remained.
I was watching an EricTheCarGuy Q&A video today and he mentioned that if your charging system (alternator, battery and wiring) is not putting out enough voltage it can cause all kinds of electrical problems. Can it cause the car to have no power (I think, yes) and idle very rough? Can it cause sensors to throw codes? I am pretty sure the alternator is not working well and the battery is way too small and struggles to turn the engine over. I'm going to replace both.
So that takes us to the car's current state. It's torn apart. Dash is out, engine is out, the whole front end is apart. I started taking things apart to trace the whole engine harness and test every wire for shorts or damage and I have found some damage and solder jobs that need replaced with a good solid crimp job. Then I got dreaming and decided to pull the engine, swap in en EJ22 block, 850 CC injectors with top feed parallel fuel rails, front mount intercooler, NA scoopless hood and a different ECU setup. Might be an ESL board for live tuning or maybe megasquirt? I know there's more power to be had even from my current setup but robtune won't support what I'm after and that's 350+ CHP.
I'm also removing anything that isn't being used anymore. Things like, ABS wiring, Cruise wiring and their computers, etc. I'm going to weigh it all for fun to see how much weight is lost. :D
Here's some pictures I snagged off my phone from recent happenings.
Cool little depinning tools for electrical connectors I got from the beaver racing japanese motorcyle website.
If your high beams quit working or sometimes shut off for a second or two look under your dash kick panel area for this connector. Mine burnt up and I couldn't figure it out for years but I think this was it. Anybody have these connectors with some of the wire length intact I'd love to buy both male and female sides to fix mine.
Fresh new timing hole cover.
RckyMtnLegacy
Post by RckyMtnLegacy »
Wow nice update. Almost mirrors my garage...white sedan, front end apart, no motor, no dash
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
Nice! Somehow I know how to put it all back together too.
Dominator
Post by Dominator »
Quite the project you're undertaking. I'm sure I have that headlight harness. I'll check my parts cars this weekend and snip it off for you. What's your plan for the RobTune? I'd be interested in it if you're planning on selling it. I'll drop you a line on Messenger about that and to get your address.
A year ago I did a full brake caliper rebuild when I was having problems with my brakes not releasing. I just finished a quick and dirty write-up on that (not that quick. Took a couple hours to upload all the pics and organize it all.) and the link to that is right here Brake Caliper Rebuild Write-Up.
ride_child
Post by ride_child »
for that headlight plug, you can just get some molex connectors from radio shack and repin them in the plugs. thats how i replaced the fuel pump plug under the back seat
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
I got nothin but time at this point. Trying to wait it out til someone can send me one. The car will be down potentially for years but if I get it finished before the plug is replaced I'll use a different connector.
ride_child
thats the thing, except not being from subaru, its exactly the same type of connector!
Kris
'91 Black SS - SOLD
Well, then maybe I should do that but I also need the pins and wires. Mine are all melted.
ride_child
is there enough extra wire to cut out the burnt shit? the plugs come with pins to install on the ends of the wires! :)
Kris
'91 Black SS - SOLD
Perfect. Yeah there's wire left.
Post by SILINC3R »
Kimo, get back to working on the car
Sublimejoe
Post by Sublimejoe »
Nice work dude!
Since you're tackling all that wiring, would you happen to know where I can find a diagram as to what each connector on the harness is for? I've searched but I must be wording it wrong :(
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
Sublimejoe wrote:Nice work dude!
For what year/model?
Sublimejoe
Sorry, 1993 non turbo wagon. It's a postal wagon if that makes a difference.
Parts Needed:
Manual Cluster
Look at pages 330 - 335 in the 92 engine & electrical FSM and let me know if that's what you're looking for.
https://www.main.experiencetherave.com/ ... and_Elect/
