Posted: Sat May 22, 2004 3:50 am
Question: an used turbo...old turbo, probably almost blown
turbo. Can it burn oil??? I mean...leak, get into the intake and get burned. Is that possible??? And if it is possible...wouldn't that look like piston rings are gone? (except that the compression would be good) I mean, wite smoke, droping oil level...you know.
When I had my intake out...it seemed oily inside...and the turbo housing seems VERY oily. Dot dripping but ...oily
