Page 2 of 2
Posted: Tue Mar 29, 2005 8:45 am
by Project_Legacy
nice. i think im just gonna buy a WRX water pump for my motor rebuild then. seems easier to find/get. so a coolant bypass cap? where would i get that? an auto parts store?
Posted: Tue Mar 29, 2005 1:10 pm
Yes.
Posted: Sun Apr 10, 2005 2:28 am
I looked at the WRX oil cooler today, and it is different then forester one I have. The outlet pipe on the wrx oil cooler is angled upwards while the forester one is horizontal. There's a possibility I can make it work, I'm just not sure if it will interfere with the header. I'll have to check it out as I dissamble things.
If not, I'll just have to sell the setup I have to one of you n/a guys.
here's pics of the forester setup
http://www.main.experiencetherave.com:8 ... oilcooler/
Posted: Sun Apr 10, 2005 5:12 am
by THAWA
The forester hard line wont work. I've tried, it runs into the exhaust.
Posted: Sun Apr 10, 2005 6:07 pm
I know the hard line won't work, I'm talking about the oil cooler itself.
Did you use the forester oil cooler, or one other one? Was it from an n/a motor or turbo motor.
Posted: Mon Apr 11, 2005 4:37 am
by THAWA
I used a WRX oil cooler because it looks like it flows oil better.
Posted: Mon Apr 11, 2005 2:36 pm
How does it look like it flows oil better? It's the same exchanger with the pipe bent slightly upward.
Posted: Mon Apr 11, 2005 5:04 pm
by THAWA
This is where my lazy self needs to go take pictures
The design of the oil flow on the inside
looks less restrictive on the wrx cooler. It could not make any difference or the turbo legacy one could flow more, the wrx one just doesn't look as restrictive. It's a different design than the turbo legacy. As far as coolant flow goes, I couldn't tell ya. But it just looks like a better unit than the old one.
Posted: Mon Apr 11, 2005 5:38 pm
Ok....I thought you were comparing the wrx one to the forester one.
Posted: Sun Apr 17, 2005 9:40 pm
Fitted the forester oil cooler on the ej22t motor. The one line is too close to the header pipe. I'm going to have to try and get a hold of a WRX one.
http://www.main.experiencetherave.com:8 ... ooler1.jpg
http://www.main.experiencetherave.com:8 ... ooler2.jpg
Posted: Sun Apr 17, 2005 10:28 pm
by IronMonkeyL255
I love my car.
*Already has factory-installed oil cooler*
Posted: Thu Apr 21, 2005 3:46 am
by kidwired
how much was the wrx cooler?
Posted: Thu Apr 21, 2005 5:37 am
by dzx
Did all wrx's come with them? usdm
Posted: Thu Apr 21, 2005 5:39 am
by THAWA
It was either 25 or 50 on ebay
Yes, infact I believe all new gen turbos except the 92-94 legacys have oil coolers. Don't quote me on that though.
Posted: Thu Apr 21, 2005 6:07 pm
THAWA wrote:Yes, infact I believe all new gen turbos except the 92-94 legacys have oil coolers. Don't quote me on that though.
Pretty sure your correct on that. Turbo foresters have them as well....and I'm assuming the LGT has one too.
Posted: Fri Apr 22, 2005 1:23 am
by dzx
Sounds like 92-94 got shafted
Posted: Tue Oct 02, 2007 2:48 am
by biggreen96
I recently put a wrx waterpump onto my 93 without factory oil cooler. I went to the store and got a little cap(get a hoseclamp too so it wont shoot off.) and capped off the extra nipple. It was very simple:
Posted: Tue Oct 02, 2007 9:20 pm
by Arctic Assassian
lol all that talk, and there's the answer. I appreciate this though, because I'm going to put this waterpump on my 91, because it's newer! peace
-Adam
Posted: Wed Oct 03, 2007 3:19 am
by bmxpunk
Odd this popped up again... I am sticking the Wrx waterpump on my car this weekend along with an 07 Sti oil cooler/heat exchanger.
Posted: Sun Jan 03, 2010 9:25 am
by biggreen96
update: that little cap sucks, I remember it broke within a month. It's the kind that Schucks, Autozone, Napa etc sells. Avoid it. I used a smaller coolant hose with a bolt jammed and clamped into the end as a heavy duty cap.
Posted: Fri Jan 08, 2010 3:15 am
by ciper
Remember if you get a "Turbo" pump you also need the "Turbo" thermostat housing.
