Crimson Room
hmm
key opens the locker, which gives you the screw driver to use on the picture n the wall which gives you a pin, poster on the wall goes under the door, pin goes in the key hole, pick up the poster again use the key to open the door.
oh, thought you meant motas. I dunno lemme try it again
click the curtain like 3-4 times and another ring will fall out, there's a key under the pillow, and metal rod between the bed and the headboard click the memo and go to the site on there in a new window and leave it open. Put the rings and rod on the box in the spaces they fit. Put the cassette and battery in and press one of the buttons to play the tape. click three times where he clicks and then o nthe thing that opens, put in the code and yhou're done
cd case is useless
I'm on level 12 now.......was getting towards the end of work and I wanted to leave.....I'll continue to play when I have time
the freaking green wall's pissing me off big time.....I'm assuming I need to pick a spot so that I can get the entire wall filled up correct?QuickDrive wrote:wait til you get to the green wall..
grrrrr
yes, start in the top left corner(or aNY CORNER FOR THAT MATTER, AND JUST GO DOWN THE ROW SO THAT EACH TIME YOUR PRESS A BUTTON IT TURNS ON ANOTHER NEXT TO IT AND NOT ANY THAT ARE ALREWADY ON, OFF. tHEN GO TO THE HEXT ROW AND KEEP GOING LIKE THAT, , ITS KINDA HARD TYO EXPLAIN BUT IF YOU TRY IT YOU LL SEE WHAT I MEAN.
sorry bout caps, too lazy to retype it
- Lurker-King
thanks....I'll give it a shot
I don't see how this will work....you can make it across the top, but it leaves gaps where things won't line up......damn green wall
I figured it out....found a description on google. You basically have to fill in all the holes on the one row...then just continue doing that.
