What would happen....
Post by BAC5.2 »
I have no idea what that engine is in, but it looks like your average, everyday boosted 420a in a 2nd gen DSM
Heh, Jason, you're probably right. :)
THAWA
Post by THAWA »
oh, thought you were talking bout something else :)
boosted5speed
Post by boosted5speed »
Actually, if im not too mistaken, that car no longer has a stock "maf" :) as the 1g DSM's have a what i think is called a vaf (vane air flow) and that car is most definately a 1g (pop-ups)
If anything its running a Maf-translator and a GM 3" maf sensor off of an impala SS or other lt1 powered car. With the GM maf and the maf-t you can use either blow through or draw through settings on the maf. Hope this helps.
<= other car = 1g dsm turbo and have had several.
boosted5speed
Oh and with the stock maf setup, it most certainly does NOT like being vented to atmosphere.
Post by BAC5.2 »
Yea, that is a GM 3" MAF. Apparently, it does work for venting to the atmosphere. I saw it done in person.
createnew
Post by createnew »
Yeah you guys are right, is a GM MAF. The stock DSMs came with a Carmen Vortex type sensor which just estimates air flow. A lot of DSM guys get the GM sensor and put it behind the turbo, intercooler, and BOV. One of the reasons they do this is to vent to atmo, another is to lean or richen the fuel mixture with the translator, plus it's way more accurate.
One thing you would have to do to use the MAF post turbo is to filter the air comming from the PCV, or just vent it to get rid of blow-by. If we were to run enough pipe to a FMIC, like in that pic, we could probably do this on our turbo Legacys. But all that piping is a waste. I may eventually try this, but I am planning on running an Air-to-Water IC setup (way more efficient.)
By the way, I am running a BOV (atmo) on my Legacy, but the only reason I can get away with it is because I have an Auto. I've had no problems except letting off of a powerbrake while still stopped, (it tends to rich out and stall.)
Yellow '01 Kaw. ZX-7R (SOLD) :(
Gold '88 Starion ESI-R (Drift Project)
Brgndy '92 Legacy SS, Agency Power Style Headers and Up-pipe (ebay, don't stay together), Underdrive Pully, 5MT conv, mod'd WRX cold air intake and short shifter, 12.5 lb fly
azn2nr
Post by azn2nr »
bringin this topic back from the dead because fat has put their stock maf's in the charge pipe and have reported good results
http://forcedairtech.com/wrx_stage2.html
edit for link with pics
-jason
scottzg
Post by scottzg »
wtf? None of this makes any sense....
Stage II Turbo Kit for the WRX and STi comes with a GT30R Turbo. This is a 5 PSI system with about a 60-80 HP gain... All of our kits contain everything to Turbo Charge your vehicle...Where as the factory exhaust is much too small for Turbo applications.
Do they know that the wrx and sti are already turbo? And how do they get a 60hp gain by dropping the boost 9 or whatever psi?
And of course i have to question the merits of installing a 500hp turbo on a 2 litre car and running a fmic... but then im no fun.
azn2nr
Post by azn2nr »
thats for the rs kits
-jason
sammydafish also put his MAF sensor in the charge pipe:
http://bbs.legacycentral.org/viewtopic. ... 326#115326
jilo860
Post by jilo860 »
its called a blow through setup. im currently doing this on my 95 240sx. it really does improve throttle response and clarity of measurements from all the people ive talked to about it. as far as having the space for it 240 - easy, lots of room legacy turbo - hard as hell unless you are planning on doing a front mount. there is just no room to do it. from what ive read and learned from people the maf must be at least 4 inches from the throttle body, or when the tb closes air will revert and disrupt the maf readings.
if anybody pulls this off on a legacy i have got to see that. cant think of any way to get that done on my legacy while still being in the realm of stock.
Post by BAC5.2 »
As of my last post in this thread (more than a year ago), I've gained a lot of knowledge about turbocharged cars.
Blow-through has proven to be extremely beneficial on high-output STI's and such.
With TurboXS, we set up a lot of blow-through MAF's, and it's had great results.
We mostly do it on rotated mount cars, so we can package things more efficiently.
To do so does require lots of computer tweaking though, but I'll talk to the guys at TurboXS about it next chance I get.
sammydafish
Post by sammydafish »
I'm running the MAF if blow through mode. Works awesome. This is an old pic. I've swapped to a new turbo and redid all the hoses. New pics comming soon. Still works the same way though. I'm on the NA engine management though, which doesnt compensate for increased air temperature with compression. I've got to imagine the turbo management as some algorythm to compensate for it. Since I'm in blow through, I don't need it (MAF reads the actualy mass of air after compression and intercooling)
- Junior
95L Wagon on T3/T4 boost :)
Post by BAC5.2 »
My only wonder is what it would do to your MAF voltage.
I'd think it'd be similar. I mean, the same amount of air that comes INTO a turbo also must come OUT of the turbo.
It should be the same. The mass of the air should not be changing as it goes through the turbocharger.
That's neat, Junior. So the sensing element can deal with the higher temperature range after all... What have you done with the PCV setup?
sammydafish
PCV is routed in before the turbo, so there's always vacuum
the systems goes in this order:
Filter -> PCV -> turbo -> IC -> BOV -> MAF -> IAC -> TB
- Junior
Hmm... so some blowby is getting into the MAF sensor under certain circumstances, but it's works anyway? Interesting.
Maybe the sensor is able to burn off whatever blowby lands on it?
douglas vincent
Post by douglas vincent »
Brydon of rallitek is running a post maf as well and it has helped him alot. I am going to switch as well next week and see how it turns out for myself.
sammydafish
Oil on the MAF became a problem when I toasted my turbo and dumped about 4 quarts of oil into my IC. It was only a problem when it got that bad. I don't really get any blowby from the motor at all. Until my turbo took a dump, there was no liquid oil residue at all in my pipes. I did have a catch can on it for a while but yanked it as the hoses were getting in my way.
If blowby is a problem, then just install a catch can. If it's really a problem, then it's time for a rebuild.
- Junior
boro
Post by boro »
So has any one done this running a Saab IC? It seems interesting, but short of placing the MAF only 4 or 5 inches from the turbo outlet, I see no way to run it with out dumping nothing but hot air through it.
I also has an atmospheric BOV so that's why I am curious.
skid542
Post by skid542 »
One thing that may/may not have already been mentioned is turbulence. The pics of the blow through MAF's have the MAF after the intercooler. By running the air through some piping and through the intercooler, a lot of the smaller turbulences have already damped out. If you put the MAF right after the turbo I would suspect that you will have some problems with getting a good reading on account of all the turbulence coming out the turbo.
Just my $0.02 which doesn't answer your question but still seemed worth mentioning.
Lee
Post by BAC5.2 »
Don't run the MAF pre-intercooler. It'll cook the MAF. and the car won't want to idle for shit.
biggreen96
Post by biggreen96 »
I think I want to try this out. However the way my system is setup is that the BPV/BOV would be installed after the MAF. Sammydafish puts his before. But it seems like that wouldn't matter very much. Thoughts?
