STI STRUTS
rally370
I did try out the STI struts on the Legacy last weekend and found very good even with some cheap 195/65x15 tyres on(saves my rally tyres).
I've just taken them off again and fitted some KSFS-22 front springs(245lbs) and rear KSRS-39 about same lbs .While the struts were off I welded in some wedges for extra strength.I do have photo's and will post them if someone can give me some web space or recommend one.
Ride height is a little higher and stiffer.Road test next week!
Cheers
Chris
Cheers
Chris
Sounds cool, Chris.
Free image hosting, courtesy of THAWA:
http://bbs.legacycentral.org/viewtopic.php?t=17062
rally370
OOHH1! forgot to say ,the reason the STI struts work for me is that you can undo the bottom nut at the base of the strut and remove the insert(after spring are removed) so then you can weld them.Plus you can replace the insert and as the insert is upside down,less flex.
Normal strut,Big bang???
Cheers
Chris
Cheers
Chris
rally370
To sum up my STI Strut swap ....
Front standard set up (USDM 04 Impreza STI) good ride height and stiffer (Spring rate 200lbs)for road.
Rear Standard set up as above but spring rate 130/200lbs(need to file out the top three mounting holes outwards by about 3/8"
With front KSFS-22 springs fitted +3/4" ride height and much stiffer(245lbs rate)
Rear fitted with KSRS-39 springs (245lbs) +1 3/4" ride height and a lot stiffer
See photo's for ride height.
One good thing is the rear spring plattform is higher on the back so now I can put on bigger tyres/wheels if needed.
I used the same brake line fitting and added tie wraps just to be sure.If I have time I will make special brackets to hold them in better.
Road test to follow.
Cheers
Chris
Cheers
Chris
rally370
Road Test:
I can either go to work via the freeway or take a canyon road???
So I took the canyon road(he he),a series of tight twists and turns up hill then down.
Nobody was about so I gave it some! The present set up seems to work very well,taught but not to the point of jarring your bones.
I have very low cost tyres on and these swealed from all fours as I made some nice four wheel drifts around the bends,infact the noise from the tyres was so bad it drowned the noise from the exhaust!
Now I find that the standard LS rear swaybar is not up to it for the road as the rear end comes out quite a lot,just the way I like it and just right for rallying???
For the road I would need bigger sway bars,energy suspension bushes rear and of course better tyres.
Total cost was $669 for the 4 complete STI Struts with shipping off Ebay , $204 for the springs and $109 for the energy front "A" arm bushings.
Next test will be Laughlin next month www.rallyusa.com
I hope this is of use to someone.
Cheers
Chris
Cheers
Chris
ultrasonic
Thanks for the road test review.rally370 wrote: Now I find that the standard LS rear swaybar is not up to it for the road as the rear end comes out quite a lot,just the way I like it and just right for rallying???
Without changing other factors, an increase in rear sway bar stiffness will tend to increase oversteer. So if you like the way the back end comes around now, you might not want a bigger sway bar.
Also, gravel and snow set ups will often use lighter sway bars to allow more body roll in the turns. This allows more weight transfer, letting the outside wheels achieve more grip. I'm no expert, but I believe I have read that somewhere, and it made sense to me. You probably know more about it than I.
I do know that better tires, appropriate for the road surface, will be a huge improvement.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
03 Legacy L Wagon
rally370
Hi Steve
I thought and have read that the bigger the rear anti-roll bar/swaybar the less oversteer?
The Turbo has a bigger rear sway bar and I sure they didn't add to induce oversteer.
I remember in the UK when the Escort RS1600 came out it would swap ends on the limit and they cured that by adding a stiffer rear sway bar.
Maybe I'm wrong??
Better tyres I feel would help as these were $30 each! you get what you pay for!!! but I only use them for going to work and they are fun to drive on.I spent my dosh on the Rally tyres.
Cheers
Chris
Maybe I'm wrong??
Cheers
Chris
Bigger rear sway bar is MORE oversteer. I am pretty sure that the turbo has larger bars front and rear, someone correct me if I am wrong. Turbo also had revised strut settings, so that could keep the steering more neutral with only the bar being different.
rally370
OOOOOPs I must have it wrong! cheers dudes.I did a bit of checking with the Alfa guys and found this link.
I must be getting old and my memory fading???
http://www.international-auto.com/index ... =ad&aid=40
Cheers
Chris
Cheers
Chris
rally370
Just pulled the STI struts off after competing on Laughlin and Seed 9 rallies and they are just as good as when I put them on.I think money well spent.
I said this before,but the handling is all oversteer when lifting off the gas so much fun!!! not a bit of understeer a bit like the old MK2 Escorts. Spring rates are 250lbs all round .
Cheers
Chris
Cheers
Chris
