And so it begins...(16G install) *updated w/ pics* No 56k
Nice! I'm impressed that you're doing this by yourself, especially with all the other stuff you also have to do.
That upper coolant line looks like it's not shaped quite like the stock one, but it's actually better because it helps keep the hose further away from the intercooler piping. Cool.
legacy92ej22t
Hehe, thanks Vikash. My friend Dan (you'll meet him this weekend) helped me a bit and Scott stopped by for a while and gave me some much needed moral support too. It really wasn't a bad project and it went pretty smooth except looking for the EGT adapter and failing and finding the bolt to plug the bung. Part of the PCV system needed reworked too but that was the worst part. I'll cover that stuff in my write up.vrg3 wrote:Nice! I'm impressed that you're doing this by yourself, especially with all the other stuff you also have to do.
Hehehehehe, actually that's the WRX one! I switched it around so that it would point back that way!That upper coolant line looks like it's not shaped quite like the stock one, but it's actually better because it helps keep the hose further away from the intercooler piping. Cool.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Cool, props to Dan and Scott for helping.
Switching the WRX line around was pretty clever... Way cool.
That's odd that the PCV system would be affected, though... was it because it got in the way of the newly relocated compressor-to-intercooler piping?
rsstiboy
if you want to increase throttle response and maximise induction noise
get rid of the 2 items I have marked in red
and replace it with a similar setup to this:-
this was my old inlet setup,
legacy92ej22t
Thanks, I'm aware of those restrictive components and do plan to address them soon. Phil's been on my ass to do the coffee cup mod for months!rsstiboy wrote:if you want to increase throttle response and maximise induction noise![]()
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
vrg3 wrote: That's odd that the PCV system would be affected, though... was it because it got in the way of the newly relocated compressor-to-intercooler piping?
Ya, the compressor outlet pointed right into 2 PCV hoses! There was no way around rerouting them.
Here's a few pics of the problem and the solution.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
I thought the conclusion we came to was that using anything but the stock air box hurts performance?
With a properly modded intake, there is no hole smaller than 3". That doesn't make MUCH difference, because the inlet and outlet on the turbo is much less than that, and the throttle body itself is only 2.75".rsstiboy wrote:have a look where the stock airbox mates up to the inlet piping, how can that be good for performance?
Plus, the stock airbox pulls air directly from the fender, unlike the cone setup which pulls air from the engine bay.
legacy92ej22t
Well, I got it all broke in last night and turned it up a bit to a mere 16 psi. OMFG it pulls sooooo hard. I mean scary fast!
Scott was with me and we were both grinning ear to ear. I can't believe the difference.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
Uhhhhh ya. You're going to be toast my friend.
It's actually weird, the entire drivetrain feels much better. The clutch is stickin' good and the car seems to shifts better too.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Damn
, lol.
I'm stoked you got it all running!
Next year, we'll see what'll happen
Oh, run 18.5lbs. If your clutch holds and you ice the intercooler, you should see LOW 13's
That reminds me, is there a 7-11 on the way to the track?
legacy92ej22t
I know this will be hard to believe but they don't have 7-11's up here!
There will be places like 'em though.
Hell, it might be low 13's now!
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Keep the IC iced and the boost at 18.5, and you'll be hitting way low 13's no problem, hell maybe even high 12's if the clutch holds. We'll hook up the Scanner to the car and see what your fuel trims look like and such so you can "tune" the boost to the fuel
Just wait until next year...
That's awsome Matt! I wish I could get a ride!!!
Let us know how you do!
-Ryan
-Ryan
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
andrew.anderson
boostjunkie
I wouldn't run higher than 16.5psi, if I were you:D
Honestly, I was going 100% IDCs at 12psi at 4000rpm back in the day:shock: I tested the engine out to 18psi sustained and 22psi (accidentally) peak with *crossing fingers* no ill-effects.
I am basing this on information that I believe Ciper provided back in the day stating the max efficiency for the 16g (at least the one I had) was at 16.5psi on a 2.2L engine. Take that for what it's worth, but that guy knew his sh!t. I don't think porting changes the turbos efficiency range (maybe it does).
At any rate, I'm guessing a 13.5-13.7 pass. Mind you, the launch will give a good work out to your clutch
Good to hear you got some new stuff in!! It's good to come back and find you guys still workin hard on those legacys!!
Jason
Jason
rsstiboy
my friend over here has a stroked 2.5 block to 2.4 ltrs with his TD05H on it and he runs 26psi, feels great down low but runs out of puff very quick in the top end, in fact my little 2ltr pulls away on 18psi from 100kph with the same turbo, for a 2.2ltr I would go for a zilla 20g with TD06 compressor from deadbolt, I think that would be a very nice setup...
legacy92ej22t
Jason dude, where you been? We're all here at my place right now getting ready for the meet tomorrow! Man, you dropped off the planet there for a while.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
boostjunkie
I've had a buncha issues I had to take care of. Long story.
Wish I coulda met up with you guys last weekend. Your car must be a beast nowadays!
legacy92ej22t
