Feels like a spark cut-off, or maybe fuel cut-off... i dunno
THAWA
Post by THAWA »
that's what I was suggesting, swap in my magnecores and see if that fixes the problem. If it doesn't you wont have to waste money on new wires.
TheSubaruJunkie
Post by TheSubaruJunkie »
Okay, then lets do it :)
I just woke up tho... I'll call you in like an hour or something hardy.
-Brain
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
TheSubaruJunkie
Yup... turned out to be a plug wire.
I removed mine and installed hardy's. I tried to install the wire to Cyl. #2 and it just wouldnt go on. After closer inspection i realized that the end of the plug wire had detatched from the wire itself and was stuck to the plug. We removed it and installed Hardy's wires. I took the car for a test drive and the problem still existed :( So i went and got new wires from the store (had to, no way I could re-use the damaged wire).
So after installing the new wires, i had to take off. The car still drove like crap. I tried resetting the ECU to no avail but after driving it for a while the problem went away :)
Now the car drives like a madman once again :)
-Brian
1986 Toyota 4Runner
Lunatech
Post by Lunatech »
That's great news!
Did you ever pull the plugs to check them?
If you did you probably noticed the #2 plug was fouled. After replacing the faulty wire it started getting spark and cleaned itself, then stated working properly again.
Congrats and good job.
Robert
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
georryan
Post by georryan »
Glad to hear you fixed it Brian. OH, and thanks for stopping by and giving us a hand. We successfully pulled the trany out after Hardy left as well.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
TheSubaruJunkie
I havent pulled the plugs. I was at Ryans House working on the curbside, and it was getting dark. When my garage is cleared I will do a thourough checkup and everything.
Ryan, glad to hear the tranny is out. Did you guys find a Tranny jack? I might be able to get one and bring it by tomorrow if you need one.
-Brian
1986 Toyota 4Runner
stipro
Post by stipro »
I found another thing that creates the bucking and backfiring hesitation. If the crank sensor gets wet, it wont get a clear reading and the ecu retards the timing intermittently as the water swirls around the lens. But this will go away as the water evaporates.
georryan
Post by georryan »
No tranny jack, just a floorjack. That 4EAT is a MOTHER. A pregnant mother giving birth to a rhino. It's heavy. :)
We've had some problems with 3 bolts on the back of the flex plate. We got 5 out no problem, but the other three are so well lodged in there that we broke one socket, and started rounding the inside corners of two others. We finally got an impact driver (no good), and an impact gun (also no good, 120 psi tank). I've since resorted to grinding the heads off. I don't need those bolts anway. Once the heads are off and the flexplate is off, pulllng the threads out shouldn't be too much of a chore.
-Ryan
2014 Volvo S60 T5
THAWA
Post by THAWA »
one word: driveshaft.
georryan
Post by georryan »
We were starting to round the bolts Hardy :)
We took a chisel to the heads as well, and even making indentions in the heads and hammering with a small sledge, they wouldn't budge. That was all after the impact stuff. If I would have done the grinder first i would have saved myself hours. :)
2014 Volvo S60 T5
Post by BAC5.2 »
In the rain, my knock sensor get's wet and retards timing to the stone age. Once it get's warmed up, it's all fine again. Sucks though.
All the more motivation for going FMIC. I can put that oh-so-useful diverter back on the car to protect some electronics from undue exposure to the elements.
