turbo install issues.
I don't understand. What part are you going to grind down?
azn2nr
Post by azn2nr »
the metal plate that holds the uppipe to the block. its attached to the other 2 studs on the uppipe.
-jason
What does it interfere with though?
azn2nr
Post by azn2nr »
the coolant return line that runs under the turbo hangs down too far and hits it. keeping the turbo from properly setting on the uppipe. i need to put a grove/channel in it to get it to sit properly
-jason
Oh, I see, it hits the uppipe's mounting bracket.
You might consider just getting rid of the bracket entirely. Some WRX owners do that when they install aftermarket uppipes, because they think it'll help prevent leaks.
azn2nr
Post by azn2nr »
is it safe? if it is ill do it.
-jason
Well, I dunno.
I know a lot of WRX people do it.
And I know most people who use OEM turbo pipes to turbocharge a factory non-turbo Subaru don't bother with the bracket.
And I know most aftermarket turbo installations in general support the turbo entirely on the pipes.
Is your new turbo a lot heavier than TD04s and VF11s are?
I guess if I were you I'd first try notching it if it's easy to do.
-K-
Post by -K- »
I think I'd try two gaskets before cutting the bracket or taking it off.
But I dont know if I'd take it off, that puts all the weight of the turbo on the DP.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
azn2nr
Post by azn2nr »
ill most likely grind it. i just saw magic mikes pics and he put the stock lines on his 34. if its doable ill do that and not have any problems
-jason
