Why does everyone always insist on spending a ridiculous amount of money on name brand parts? Subaru OEM parts are very very high quality. Do this:corsair wrote:ok, well looking at all the things said it looks like the following
new pistons from crawford around 11-12:1
head work: porting, polishing, valve springs, cams
do it in an N/A block but a turbo block would be considered optimal for durability
engine management would be a p.i.t.a just considering buying a motec or something is scary ($$$)
anything else?
http://bbs.legacycentral.org/viewtopic.php?t=19431
And if you are serious about some real power, you will pitch the Ej22 heads and get some Ej25 heads. And then you can run a set of the Syms ITB that are available. But this only if this is more than just bench racing.
BTW, both Diz's hybrid that I built and my 2.5rs engine run 11.5:1 CR on pump gas with stock ECU's and no detonation...
And my next project has started. We are building an EJ20G block with EJ22T heads. Should be a CR in the 9's, and then we will boost it with a vf-11 at 8psi or so. We figure it won't set any records, but should at least net us 200+ at the crank...
