Hella 90 mm headlight conversion
The lenses aren't done yet, they still need polishing. They are a huge PITA.
I'm thinking of maybe making duplicate housings with brackets if people are interested and people could dress them up as they want. I could do Impreza housings also, if wanted. I guess I'll see how people react at the Subaru meets.
ej22t
Hi Steve, I am interest on this DIY headlight mod. and would like to have more detail since you did it really well.
Could you take more pics on your prossess and post them up so we will have a guide line to make our own.
Keep up the good work and waiting to see the finishing.
Ben
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
I'm not done with them yet. Once I polish the lenses completely I can post the pics of the headlights. The instalation pics will take a little longer. Some minor cutting will be necessary to get them in the car and then I'll have to wire in the new connectors. Weather here sucks really bad, so I have no idea when that end will get done.
I'd easily be able to do mounting assemblies for people and they would come out a little better. How you finish them would be up to you. I could source light housings here or you could send them to me, either way.
I'll try to get a shot of the still-clouded lens on the housing tonight.
Have you test fit them on the car yet? Does the opening in the frame need expanding?
Eye-measuring them, I need to open the hole on the inside of the car behind the headlight a little towards the outside of the car as the low beam is fairly deep. I think the inside piece will be fine. I shouldn't have to relocate anything. And here's the assembly with the lens. Still waiting for the hex-metal to fill in between the lamps. They're still a little cloudy, but almost there.
Steve when you say hex metal are you referring to something like this? http://www.mcmaster.com/itm/find.ASP?ta ... g=92725T22
Because I just thought about water damage, or just water getting in the light itself, condensing on the glass, and impeading light output or something like that.
Or, I just realized, are you using the stock rear housing? I didn't think you could with the larger size of those Hellas, unless you're cutting it.
Sam
'93 L AWD Wagon
'08 Honda Civic Si Sedan
'93 L AWD Wagon
The stock rear housing is what the beams are mounted to. The lamps themselves are sealed so water won't be an issue. I thought of the condensation issue, but there should be plenty of air able to get in there - better than having it closed off. If I do have an issue, I can glass in the back.
That link doesn't work, but I'm sure it's the sam stuff as that's where I'm getting it from. I am doing the housing black and maybe painting the hex alloy body color, black, or dark grey depending on what I do with the grille. If I do the hex metal in black, I'll set it off a little with a dark grey for the housing behind it.
Another option, if a little ricey, would be to hole saw the lenses for the lamp openings and cover the rest with that carbon fiber sticker stuff.
greg donovan
ericS2the6
would it be at all possible to move the lamps closer together? i think it would be more aesthetically pleasing, like just move the inner high beam to the outside. looks like you have some room from pics
then i think it would be quite simple if you got a sheet of aluminum or similar and cut somes holes in it and rolled it a bit. you could go crazy with the design, i attached a photoshopped image and a crappy MS PAINT drawing
just some ideas.
i think this could come out quite good.
some photoshop fun:
just some ideas.
some photoshop fun:
tris91ricer
- Title Whore
*KICKS FEET IN AIR*
ILOVEITILOVEITILOVEIT!
*DONE KICKING*
The rolled aluminum idea is pretty trick, too, although a tad flashy.. but make it optional, and it'd be golden. (pun intended
Steve, what's up with the lenses? Are those stock, and then you've scrubbed/sanded 'em so hard they're clear? I must know!
*DONE KICKING*
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
Oh man, Im so gitty.
Fiberglass man!
Cover the lenses with foil. Take grillcloth, or T shirt material, and attach it to the stock housing frame. Push the lenses in the frame mount, and apply resin. When it dries, cut out the holes for the lenses, sand down, and paint whatever color you want.
Really easy to do. Ever see how they make "tubs" for sub enclosures?
Wish you live a bit closer.
Fiberglass man!
The lenses are the originals, sanded, sanded, sanded, resanded, and polished.
I aranged the lamps in the positions I did to my preference as I didn't want too much dead space on one end. It would be a great spot to put a blinker in, though. But whatever, the lamps can be arranged anywhere horizontally in relationship to each other. If you want them close together outboard, that can be done.
I'll be showing them off at the Speed & Feed this year and may take orders for making the housings to spec (like if you want the lamps outboard or wherever, I'll do them to your preference). How you cover them will be up to you - fiberglass, cleared lenses, nothing at all, whatever. There are tons of interesting posibilities and I'll leave them up to you. Hell, you can even just change the face of them and leave the housings alone for differnt looks if you really want to go nuts.
I could reproduce the housing mountings pretty cheap and you could just add lamps and whatever personal touches you want after. I can source old headlights locally (probably), so that would save on shipping.
I'm going to try to mount these this weekend, weather permitting.
Damn, I'm retarded. I should have done mine that way!rallitektech wrote:Oh man, Im so gitty.
Fiberglass man!
You could make some tubing out of cardboard or thin alloy and glass that in so that the lamps are set into pockets also.
tris91ricer
- Title Whore
Project_Legacy
Turn the bulb and pull it out...I think. It's been a while.
Project_Legacy
