Look what followed me home...
Nomake Wan
I updated the pics. I put the engine in the engine stand. Had to buy some grade 8 metric bolts that were long enough to hold the motor to the stand....damn things were pricey though.
I laid out the wiring and everything.....what a mess. I'll probably just be using little connectors here and there.....other then that I'll probably just run my own wiring.
I did some spring cleaning too....I'm running out of room in the garage....hahaha
http://main.experiencetherave.com:8080/ ... ges/ej22t/
Tell me about those damn mounting bolts! I had to go all over the damn place to find the odd size bolts long enough to fit. I think they are M10 x 1.25? It was the pitch that was the real PITA to get right.
Yup, M10 x 1.25 x 100 mm.
They were like 3 bucks a freaking bolt!!! Insane!
I think I paid about the same and they're not even stainless for crying out loud. If they were either 1.0 or 1.5 pitch they would've been cheaper and easier to find.
Grade 8 isn't a metric designation. Did you get class 8 or class 8.8 bolts? Metric class 8.8 is similar to SAE grade 5.
Not that the 830 MPa tensile strength of class 8.8 will likely be a problem with 10mm hardware...
Where did you end up finding such long M10x1.25 bolts? I know it's the same threading as a lot of the exhaust fasteners but those are all much shorter.
Mine were just short of 100 mm, but it's all I could find. I either found them at Brittons Auto Parts or ordered them from McMaster, I don't remember, but I think I bought them locally.
90mm would have worked, but 100mm was all they had.
There's a specialty hardware store near me called Bearings. They have some more unique/specialty stuff.
93EJ22-Loosy
hey josh,Legacy777 wrote:It was only a matter of time, and waiting for the right time & opportunity. I got what I think is a screaming deal on everything.
define screaming deal...I am dying to get a pallet like that of my very own.
redesigning my '93 Leg Wag in my head...and then looking at my bank account...and crying.
Cant believe there are more of me out there!!!
Updated pics
http://www.main.experiencetherave.com:8 ... s/ej22t/02
http://www.main.experiencetherave.com:8 ... s/ej22t/03
http://www.main.experiencetherave.com:8 ... s/ej22t/04
You mean westbury, PA?
Not really, but I did mapquest it, and see that's it's south of allentown area near norristown.
oh.....no I don't think I know where that is. What part of town is it in?
I made a page that has links to all the pics. Easier to know when things have been updated.
http://www.main.experiencetherave.com:8 ... ges/ej22t/
New pics from today's block dissambly can be found on there.
updated pics.
Added pics of the heads and all the parts I've bought.
Just thought I'd make mention of a few things I noticed today when yanking stuff out.
The bumper beam pieces that protrude outward. I'm not sure if cutting them is a good idea. They look to be spot welded at the tip. I think I'm going to try and bend them to give me the clearance I need for a radiator for the AWIC.
Other thing, I got the walbro pump.....that thing is freaking puny.
Here's the latest pics
http://www.main.experiencetherave.com:8 ... /ej22t/17/
I ended up picking up one of these.
I picked up the 19,000 gvw version (130-70268). It is thin. It will fit perfectly between the radiator and the ac condensor. The only problem is the size of the pipe inlets, its a bit smaller than I expected. I may get another one and run them in parrallel or series. I could easily fit two in there. Otherwise I have another small heater core I could run in the bumper maybe, its just a bit too wide.[/url]
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
So there's that much room in between the condensor & radiator?
I was going to put something in front of the condensor, but if there's room to put it behind the condensor, then why not.
I need to see how much room I have, and what's available without getting something custom built.
Man, I'm freaking beat. Engine is out.....that was cake. Getting the A-arms off was A LOT more difficult. Those damn ball joints!
I spent quite a bit of time getting the front bushings out of the A-arms. We pressed the inner portion out, and then I bought a sawzall and cut the outer metal portion of the bushing and chiseled enough of it out so it came out. I'm going up to a guy's house next weekend to press the new sti bushings in. Should be less of a pain.
I need to clean the garage up....it's a disaster.
http://www.main.experiencetherave.com:8 ... /ej22t/18/
Manarius
Why did you have to pull the steeing rack for a engine change? Heh...I just noticed you and I have cars of the exact same color and year. Mine is just a "natural" AWD
I have to swap front crossmembers for the stock turbo up pipe to clear things. In order to do this, I have to swap the steering rack too.
