AWIC vs WRX Intercooler
Front, Top, Air, Water.
-K-
Post by -K- »
I just cut the inlet and outlet pipes with a hacksaw and put hoses on. I think I had to do something with the inlet because it was so small. I can't remember exactly now what I did. Maybe welded a bigger pipe on the flange that bolts to the condenser or drilled and tapped it for a NPT barb fitting.
I got an aftermarket upgrade pump for a Typhoon. I just started searching for Typhoon stuff.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
douglas vincent
Post by douglas vincent »
I am just using a small external oil cooler that measures 6x12 or so and just stuck it down in front of the radiator. I do not have an AC rediator, much less AC.
I have never had the water get hot, or even warm. Then again, I havent driven it hard in the summer.
-K-
Post by -K- »
Yeah if I was to do it again i would just get a big tranny cooler and stick it in front of the radiator. I would go to a truck parts store to get a big one.
The stock radiator for the AWIC is pretty small and does well up to a good amount of HP.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
Not sure if anyone has seen this, but it seems to have a lot of good info.
http://www.netcomuk.co.uk/~gavinp/airwater.htm
I've only skimmed it so far.
