Page 2 of 2
Posted: Tue Mar 15, 2005 8:31 am
by -K-
I just cut the inlet and outlet pipes with a hacksaw and put hoses on. I think I had to do something with the inlet because it was so small. I can't remember exactly now what I did. Maybe welded a bigger pipe on the flange that bolts to the condenser or drilled and tapped it for a NPT barb fitting.
I got an aftermarket upgrade pump for a Typhoon. I just started searching for Typhoon stuff.
Posted: Wed Mar 16, 2005 4:13 am
by douglas vincent
I am just using a small external oil cooler that measures 6x12 or so and just stuck it down in front of the radiator. I do not have an AC rediator, much less AC.
I have never had the water get hot, or even warm. Then again, I havent driven it hard in the summer.
Posted: Wed Mar 16, 2005 7:48 am
by -K-
Yeah if I was to do it again i would just get a big tranny cooler and stick it in front of the radiator. I would go to a truck parts store to get a big one.
The stock radiator for the AWIC is pretty small and does well up to a good amount of HP.
Posted: Fri Mar 18, 2005 3:27 pm
Not sure if anyone has seen this, but it seems to have a lot of good info.
http://www.netcomuk.co.uk/~gavinp/airwater.htm
I've only skimmed it so far.
