Boost holding nicely until 4k+ RPM... then dropping
Does your stock or hybrid stock turbo hold boost until redline?
Yes
4
27%
No
5
33%
No, but my 16G does. Jealous?
4
27%
Shit! Bonerz
2
13%
Total votes: 15
Flip_x
Post by Flip_x »
does anyone elses car does this? my first two gears the boost drops then after the first two gears like in third fourth and fifth it keeps it to redline??
1990 Legacy Sedan LS AWD 5-MT 162k miles Slate Metallic (Sold to Brother)
1992 Legacy SS AWD 5-MT 180k miles Mica Black
free5ty1e
Post by free5ty1e »
(Flip X... you've redlined 5th?! You a brave mofuggah!)
-Chris
91SS 4EAT stock, 200k mi
Flip_x
Post by Flip_x »
oh god no. maybe on my drive to vegas soon.
-K-
Post by -K- »
My Hybrid holds 15psi to redline.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
free5ty1e
Post by free5ty1e »
K - tbird/vf11 hybrid? Or another hybrid?
What are you using for boost control? BOV?
-Chris
-K-
Post by -K- »
T-bird hybrid turbo. Bleeder valve for boost control. Stock bypass valve that might be causing some problems.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
FuJi K
Post by FuJi K »
so with my setup, is it safe to run 12psi?
EJ22T
TD04 w/ WRX TMIC
STOCK Metal MAF
STOCK INJECTORS
WRX fuel pump
I have the black plastic MAF if that works. Will my injectors be maxing out at this 12psi with the WRX fuel pump?
MY99 GF4 5spd DIY Modified
You'll probably max out the MAF.
From what I've heard/read the turbo legacy pump actually flows more then the wrx pump. So you may want to keep an eye on things with a wideband.....at least to initially check it out.
