Suspension Information Compendium -what fits, tuning info
scottzg
Post by scottzg »
More info added!
dscoobydoo
Post by dscoobydoo »
Add: 2.5 RS sway bars are 13mm front and rear. Too small if you ask me.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
scottzg
Post by scottzg »
2.5rs bars dont fit on a legacy. hence DNW- does not work.
THAWA
Post by THAWA »
I dont believe GD/GG rear sways work either. They're flat where the spare tire is just like GC/GF/GM bars.
Question though. You say the SPT springs for the GD don't lower the car, what about the SPT springs for the GC chssis?
scottzg
Post by scottzg »
i dont know. I got that quote directly from a pm. I think gc and bf have the same strut/spring height, but thats only based off what i've got.
THAWA
Post by THAWA »
so the second gen's have a different strut/spring height?
95LAWD
Post by 95LAWD »
Subaru has at the dealership, an upgrade kit from SPT for the '01 and older imprezas that will drop it 1.4" front and 1.2" rear. It costs about $218 but for me, less than $150 because of my employee discount.
Anybody have any idea what sort of realistic drop on a '95 legacy sedan (awd) and ride it would have?
'95 Legacy L (red)
'98 impreza 2.2L wing (black) '93 impreza L front bumper (red)
195/60/R15 on 15" 6 spoke alloys (they're common)
Ej22, OBD II, dual port, 9.5:1... l
scottzg
Post by scottzg »
about the same, but the rear will drop a touch more. At least, that's how it would be on a bc
gnuman
Post by gnuman »
Does anyone have numbers for the '92 SVX? Will they fit a 92 Legacy wagon? Are they stiffer? softer? what about ground clearance?
1992 Legacy L Wagon 'Emily" Ice Blue, plush seats, roof rack, towing hitch, upgraded radio/CD player, LS alloy wheels, and lots of love! 180K miles and going very strong!
You will get my Legacy from me when you pry my cold dead fingers from the wheel.
scottzg
Post by scottzg »
SVX suspension is completely different. The front swaybar connect the the struts, and the rear is multilink. It's possible it bolts up, but it didn't seem worth exploring.
scottzg
Post by scottzg »
I just did a major update to the Compendium itself. If you see any errors (PLEASE CHECK!!!) please PM me and let me know! Thanks.
THAWA
Post by THAWA »
The SVX springs are real soft for the car. 140lb/in front and 110lb/in rear. They may or may not fit. The whole swaybar connecting to the strut deal shouldn't affect putting them on a legacy, but vice versa wouldn't work. The rear suspension is essentially the same as a legacy, but it has a semi-trailing arm, instead of a trailing arm. But as scott said the rest is completely different, the front arms are more of an "A" shape than an "r" shape. and the swaybar is like three parts instead of being one solid piece. It makes for a car that handles better stock than at least a lightly modded legacy.
The Scooby
Post by The Scooby »
im wondering, im getting WRX wagon springs, i want them on my legacy struts, but im going to use wrx rear struts, will this work, for me this isnt really lined out too clear for me.
also with the rear springs for a AWD wagon (legacy) having 190 rate, and a rex wagon having144 will it sag in the rear?
Thanks,
Shean
1986 GL wagon
EJ'ed and Lifted
scottzg
Post by scottzg »
yes, with the correct hats.
yes.
The Scooby
scottzg wrote:yes, with the correct hats.
yes.
so yes with wrx wagon top hats it will work in the back?
and it will sag in the rear with stock wrx wagon springs?
also will the front springs work with stock strut tops?
1986 GL wagon
EJ'ed and Lifted
scottzg
Post by scottzg »
The Scooby
well again that just confuses me,
what about a set of e-bay specials coilovers for a 97-01 impreza, will those work with stock strut tops? or would i have to use the WRX/GC impreza ones, my strut tops are for the tapered rear springs.
1986 GL wagon
EJ'ed and Lifted
scottzg
Post by scottzg »
How could i possibly make it easier??:evil: :evil:
the e-crap coilovers will bolt up to a 92-94 strut and spring perch. They'll have to be adjusted to fit 90-91 struts, but they have like 16 million inches of travel, so it will work. The 90-91 perch will not work. Who knows what the rate is on those springs, i bet its waaaay off of what you'd want.
Wrx wagons have a softer spring rate and are lighter in the back, so its easy to assume that the back will sag and your handling will be compromised.
90-91 spring perches are completely incompatable with 92-94 legacy/impreza springs.
The Scooby
ok thank you, now one more question, does 90-94 have rear tapered springs, or was it only 92-94?
1986 GL wagon
EJ'ed and Lifted
scottzg
Post by scottzg »
The Scooby
thank you
1986 GL wagon
EJ'ed and Lifted
jamal
Vendor
Vendor
Post by jamal »
Hey so you know how some cars don't have rear sway bars? I'm pretty sure that it's just L models. I was driving behind a 93 or 94 LS AWD today, and it had a rear bar, where as my 93 L AWD does not (yet).
peter@functionauto.com
THAWA
Post by THAWA »
Were you going somewhere?
jamal
Vendor
Vendor
Post by jamal »
I was driving down a city street at work. I always wondered why some cars had rear swaybars and some didn't. Apparantly it depends on the trim level.
All the 90-91's got them. In 92-94, the lower end trim levels didn't.
