Gauge Installation?
LaureltheQueen
- Spelling Nazi
Well, I could try and borrow my mom's husbands digi camera...and then drive over to where I keep the turbo now...But with my GT's tranny/clutch problems, I might not have time today. So it probably wouldn't happen till tomorrow...sorry. I'll try though.
Micum
Micum
Micum
97 Legacy 2.5 GT - mod'd
93 Impreza L AWD (sold)
97 Legacy 2.5 GT (deceased)
98 Legacy Outback (sold)
LaureltheQueen
- Spelling Nazi
A very easy way to wire temporarily (or permanently if you want) is to run the black ground wire to the chassis, then put the red wire into one of the fuses in the fuse box under the dash. Just strip the end of the red wire, find a fuse that only gets power when the lights would be on (power windows for example), and stick the wire into there. Just push the fuse in over the wire and it will hold itself. You'll be able to at least tell if the gauges are working properly.
MK
MK
1992 BC672 AWD 5MT
had you been able to check the wires in the ashtray light harness (assuming this is what you ended up using) with a multimeter to make sure they are getting current? Your ashtray light worked previously right? Maybe there is another place to tap electric someone can suggest. If not one that is switched on with the illumination, then maybe one that is on whenever the car is on, just to make sure the gauges work. I don't really think the quality on the indiglo gauge setup is that good, nor procarparts or any ebay sellers of these...so its quite possible its the gauge setup itself.
Hope you get it soon...
Micum
Micum
Micum
LaureltheQueen
- Spelling Nazi
LaureltheQueen
- Spelling Nazi
LaureltheQueen
- Spelling Nazi
LaureltheQueen
- Spelling Nazi
It may be a longshot...but have you tried checking the fuse for the indiglo gauges? Its in the white tube thingie attached to the red power wire.
Worth a shot.
Micum
Worth a shot.
Micum
Micum
LaureltheQueen
- Spelling Nazi
