Posted: Mon Mar 20, 2006 4:34 pm
This is something I didn't know and probably good to point out. My N/A->turbo setup uses the MAF in blow through operation, so the IAC input from the pre-TB intake is post turbo. This makes me not need the valve in the IAC. Anyone that's doing this swap and using the N/A IAC/Manifold should probably route the IAC post turbo to avoid potential issues with pressure bleedback.scuzzy wrote:One thing that's interesting, if you've inspected the differences of the turbo manifold and the Na manifold (other than the obvious extra outputs/inputs) is that the IAC has a bleed-back valve which prevents pressure from escaping the manifold back to before the turbocharger.
This is because the turbo block yileds less compression. You'll make less power with this setup too. Of course, when you get around to strapping that turbo on, you'll be able to run more boost.scuzzy wrote: There is a fuel difference, with the old engine I saw a typical 22-23mpg in the city and upwards of 26 on the highway.
with this setup I see 19-20mpg in the city, and about 25 on the highway.
good writup
