Page 2 of 2
Posted: Fri Dec 20, 2002 7:36 pm
by ciper
Since you have the coil removed already, think about running a ground wire from under it to your central ground point (if you have one).
Posted: Mon May 26, 2003 8:23 pm
by mTk
Just ordered the MSD 8229 coil pack. Then saw this thread :D
I'll let you know how it goes.
MK
Posted: Tue May 27, 2003 4:49 pm
by ciper
I should mention that you have to make sure and use a coil that is from a vehicle without the integrated ignitor.
Posted: Tue May 27, 2003 5:24 pm
by morgie
ciper wrote:Since you have the coil removed already, think about running a ground wire from under it to your central ground point (if you have one).
FRom under it ?? where do you attatch the wire on the coilpack ?
Posted: Fri May 30, 2003 12:36 am
by mTk
MSD Coil pack 8229 came in today. The bolt holes are different, either top 2 or bottom 2 can both go in at one time, but not both. It is more of a rectangular shape. Not an issue for me, i'll find a work around :D
I'll be stopping by the local mitsu dealer sometime next week to find out about the connector, and will try a few salvage yards.
Contacted Magnecor about making custom wires
MK
Posted: Fri May 30, 2003 1:47 am
by ciper
Mk750: Why did you get the coil pack? I dont think the coil is the week point, the ignitor is. (even if you dont have the diamond pack)
morgie: Attach the ground between the copper portion of the sleeve of the coil pack mounts and the raised/threaded portion of the throttle body.
Posted: Fri May 30, 2003 2:37 am
by mTk
cip: I figure i'll upgrade everything that i can.
mk
Posted: Fri May 30, 2003 3:00 am
by ciper
Are you going to run the MSD coil with the stock ignitor? Dont you worry about the resistance values being so far off? I think you should get an extra ignitor and keep your old one just in case it ruins it.
Posted: Fri May 30, 2003 6:07 am
by mTk
Actually, with college/work/no license I don't have the time or patience to work everything out.
So you do get your way after all, ciper :twisted: j/k
MK
Posted: Mon Jun 23, 2003 3:06 am
by legacy92ej22t
was looking at my coil pack today and I don't know which it is.It doesn't say hitachi or diamond.It has the little swoosh symbol and the part # is 22433AA230 CM12-100 12V.anyone know which it is?thanks
Posted: Mon Jun 23, 2003 3:32 am
Both types of packs are made by Hitachi, I believe. The Diamond ones say "Diamond" on them. Yours is the plain ol' Hitachi coil pack.
Posted: Tue Jun 24, 2003 4:49 am
by legacy92ej22t
ahh that sucks :( oh well add another thing to my parts list :) thanks
Posted: Tue Jun 24, 2003 6:57 am
by teaguespeed
what makes the Diamond coilpacks better?
Posted: Tue Jun 24, 2003 1:36 pm
They're just wound in a way that makes for a higher voltage spark, I think.
Posted: Tue Jun 24, 2003 11:45 pm
by legacy92ej22t
checked my friends 93 legacy L and he has a diamond.diamond on a L and a plain 'ol hitachi on a turbo.hmmmm..go figure :roll:
