Page 2 of 2
Posted: Thu Aug 25, 2005 2:55 am
by gt350
[quote="-K-"]gt350, yup Reeve's Capri. That thing is a monster when the boost comes on. I should have guessed you were a 2.3 guy, nobody else seems to know about them Holsets.
[quote]
yeah the DSM guys and Honda boys are starting to jump on the holset bandwagon as well. I'm excited to get my HX35w installed. I made a DP for it saturday and plan on installing the turbo and downpipe tomorrow. then i'll have to get my charge piping made for the intercooler. good thing I do all my own fab work or i'd be broke as hell. I'm going to try and put my stock t3 60trim (equivelent in size to a 16g) on the suby. figured it won't be too tough. just make a uppipe and dowpipe then install on of my many intercoolers and see how it works.
and the best thing about reeves car is it's almost all stock parts. 12.6@108. cant argue with that.
Posted: Fri Aug 26, 2005 1:52 am
by NICO
thawa i was only estimateing that i had 350hp. i siad i can feel that i have 350hp and someone on this board he blew it out of porportion, and here we are talking about it.
i am talking to deadbolt rep and i think he might be a little to expensive for me.
Posted: Fri Aug 26, 2005 6:51 am
by Kelly
350 is impossable on a vf11.
I hate to do plugs for the shop, but.
http://rallitek.com/products.asp?ID=543 ... =&ACC=&SP=
It looks to be similar to a 34, but they have their own turbines and housings. We havnt recorded any hard data on them yet, but the butt dyno tells me this is the turbo going on my motor. And, its super cheap.
Posted: Fri Aug 26, 2005 7:23 am
by azn2nr
580 cfm is tons. more than the 16g
Posted: Mon Aug 29, 2005 6:23 am
by 555BCTurbo
gt350:
I am a friend of Reeves as well, and have ridden in his monster
Are you running those times in a TurboCoupe??
If so thats pretty damn impressive, as those cars are pretty hefty
Those 2.3's are too crazy...you take like a $200 fox body car and a $300 junkyard motor and you are running 13's
Posted: Tue Aug 30, 2005 4:35 am
by gt350
555BCTurbo wrote:gt350:
I was talking about reeve's capri. thats his best run to date. yeah but I should be putting down some good numbers once I get everything on. i'm shooting for high 11's for now.
pretty much is nothing is untouched. but I still have to fab up an intake manifold and an intercooler pipe from the IC to the throttlebody. you'll find that us turboforder's are a different breed. we dont buy stuff. we make it.
Posted: Wed Aug 31, 2005 6:54 pm
by NICO
well i talked to the nice pepole at deadbolt and i dont no, its going to cost me a lot for a tdo5h-16g made to fit my car, 775.00 american dollers. if that price was canadian i would be all over it.
what other options do i have for a turbo upgrade.
Posted: Thu Sep 01, 2005 9:42 pm
by NICO
is a tdo4l wrx turbo better then my t-bird set up.
Posted: Fri Sep 02, 2005 2:45 am
by gt350
NICO I WRX U wrote:is a tdo4l wrx turbo better then my t-bird set up.
no! the td04l 13t is tiny not much bigger than a stock vf11.
Posted: Fri Sep 02, 2005 4:53 am
by -K-
There seems to be a pretty big diference in what people say a VF11 is "good for" and what a "very small upgrade" td04 will make for HP in a WRX.
It's really starting to bug me, someone is wrong......
NICO, buy the VF30 you talked about and make it fit. It'll be better than the turbo you have.
Posted: Fri Sep 02, 2005 5:50 am
by NICO
sounds good k its at a good price i am going to get it.
Posted: Fri Sep 02, 2005 1:22 pm
by legacy92ej22t
-K- wrote:There seems to be a pretty big diference in what people say a VF11 is "good for" and what a "very small upgrade" td04 will make for HP in a WRX.
I think the big diffrence is the heads on the WRX and the engine management. What the TD04 is capable of on a WRX and what it will do on an OEM controlled EJ22T are very different.
Posted: Fri Sep 16, 2005 12:58 pm
by Bane
sorry i'm late to the game here.
-K-
are you saying that a td04 on ej22 would make a big difference? or that it's not a small upgrade and the install is a pain?
I'm still on the stock vf11 and i'm not looking at insane power, just something a little higher then stock.
Posted: Sat Sep 17, 2005 2:41 am
by -K-
I don't think It would be a huge gain to go to the TD04 but it would be better if the claims of the "most" you can get out of a VF11 are true.
I'm not sure if the amount of work for the install would be worth the gain, for stock EM, and if you are going to get better EM you should aim for more power than a TD04 can supply.
If you just want a bit more power get your exhaust done. Get an IC on and raise the boost to just under the FCD. It'll make you smile every time you see an on ramp....
Also I was a pretty happy with stock power after I did the struts/springs. Like way happy, I still wanted more power but I couldn't hold back the grin at every corner.
Posted: Sat Sep 17, 2005 4:21 pm
by Bane
i hear what you mean.
I recently did the suspension, and it's made a BIG difference, but i think i may try and lower it from stock WRX setup, for just a little bit lower centre of gravity.
With the exhaust and the dual stage boost controller, i'm having an absolute blast over the last week or so.
can't wait until in the intercooler is in.
lol, for shits and giggles i looked up the deadbolt site.
that 16g setup for the Legacy sounds nice.
pretty sure i won't be dropping $750usd at this time, but sounds nice none the less.
Posted: Sun Sep 18, 2005 2:13 am
by NICO
hey james ya that 16g would be nice but i dont got the money yet for it, some thing will come my way.
Posted: Thu Sep 22, 2005 11:07 am
by NICO
if i put a stronger wastegate acutuater on my vf11 t-bird set will i blow the turbo up?
Posted: Fri Sep 23, 2005 6:26 am
You don't need a stronger wastegate actuator -- you can put a spring in parallel with the existing one:
http://www.graphics.cornell.edu/~v/pics ... legacy.jpg
As to whether you'll blow the turbo up, you can just think of it as an equivalent to an MBC. If you increase boost pressure too much, then, yes, you could cause damage. But if you do it an appropriate amount you should be okay.
Posted: Fri Sep 23, 2005 7:21 am
by NICO
dame vrg3 your a sneeky mother#($)%,
i like your style. my dad is going to lose is mind and kill me if he sees that hahah.
so if i have my turbo boost at 16psi and put that spring on will it give me more boost. for some reason i cant get past 16psi no more, before i could run 20psi with my vf11.
Posted: Fri Sep 23, 2005 3:42 pm
Uh... maybe... but 16 psi is already pretty high for that tiny turbo. I don't think you should run 20 psi with it.
Posted: Fri Sep 23, 2005 4:25 pm
by NICO
everything i have done on my car has bin so easy to do but this turbo problem is killing me. it looks like i am forced to spend a 1grand.
the vf30 deal was a no go tod5h16g is to much, cutting and wellding will take for ever, tdo4l is to small i dont no no more.
Posted: Fri Sep 23, 2005 7:58 pm
by Richard
20 psi out of a vf11? you're a brave, brave person.
Posted: Sat Sep 24, 2005 10:45 am
by NICO
i try i try haha i have like five of them one blows put another one in.
ok i might have another idea, what about sending my turbo to dead bolt and getting it ported and the works on it, maybe they could put bigger fans in it, or should i send in my tdo4l and get this one done becuse its newer and might have better options.
vf11 or tdo4l all on setriods? what one would be better.
