AC still works just fine.
Exactly - that black electrical box in the middle/top of the firewall is the ignitor. The first place I moved it, where it died, did not require any lengthening. That's why I put it there - I was lazyjake15 wrote:yes. if you want to move it to where he moved it, yes i believe it will require extra wiring (just lengthening) the harness will let you move it about 1/3 to 1/2 of the way to where he mounted it......LaureltheQueen wrote:is the ignitor the thing sitting smack dab in the middle of the firewall on that bracket? Did moving it require any kind of extra wiring, or was the harness long enough to go all the way over there?
Yeah, seems like there's a lot of different AC line setups (depending on whether its been retrofitted? year? turbo vs NA? manual vs auto?). When I popped my hood, Vikash and Phil and Matt were like "what the heck is that AC line??? did someone replace it with an NA line already???"Bane wrote:hmm, then it must be a difference in the a/c line between the production years
1. BAC is running both IC inlets. So am I.Bane wrote:okay so i relocated the ignitor, moved a couple of the wires and stuff under the pitchmount, basically freeing up some more room.
So here are some questions:
1. Bacs, are you running to both ic inlets or just one side?
2. is your a/c line being held down by something or just loose and resting against the underside of the inlets and y-pipe?
3. Where is your coolant tank?
4. how much did you shave off the tb or ic?
5. what kind of bov is that?
hmmm, that's it that i can think of for now.
nope, i dont think i'm the first either...... but mines been running with both inlets for a little over a yearBAC5.2 wrote:1) Yep. Both inlets. As far as I know, I was the first to get both inlets to properly work.
